Hey guys,
I am completly new to home assistant. So sorry at the beginning.
I have a little problem. I am trying to add a Fibaro Roller Shutter 3 to my home assistant. I have a Aeotec Z-Wave Stick Gen5 on a USB Hub (cause of the problems when the device is directly plugged in to the RPI) running on a RPI4 and I think the stick is set up correctly.
I build in a Fibaro Roller Shutter 3, and the manual function is working (you can also hear that the shutter is doing something). Now when I click “Add Note”…Nothing happend. I mean absolutly nothing.
2020-12-15 16:54:09.597 Always, OpenZwave Version 1.4.3469 Starting Up
2020-12-15 16:54:14.288 Info, Setting Up Provided Network Key for Secure Communications
2020-12-15 16:54:14.290 Info, mgr, Added driver for controller /dev/ttyACM0
2020-12-15 16:54:14.290 Info, Opening controller /dev/ttyACM0
2020-12-15 16:54:14.290 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2020-12-15 16:54:14.293 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2020-12-15 16:54:14.294 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-12-15 16:54:14.294 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-12-15 16:54:14.294 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-12-15 16:54:14.294 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-12-15 16:54:14.294 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-12-15 16:54:14.294 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-12-15 16:54:14.297 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2020-12-15 16:54:14.297 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-12-15 16:54:14.297 Info, contrlr, Static Controller library, version Z-Wave 4.54
2020-12-15 16:54:14.297 Detail, Node045, Expected reply was received
2020-12-15 16:54:14.297 Detail, Node045, Message transaction complete
2020-12-15 16:54:14.297 Detail, contrlr, Removing current message
2020-12-15 16:54:14.297 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-12-15 16:54:14.299 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xe2, 0x93, 0xf9, 0xa2, 0x01, 0xfd
2020-12-15 16:54:14.300 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xe293f9a2. Our node ID = 1
2020-12-15 16:54:14.300 Detail, Node147, Expected reply was received
2020-12-15 16:54:14.300 Detail, Node147, Message transaction complete
2020-12-15 16:54:14.300 Detail, contrlr, Removing current message
2020-12-15 16:54:14.300 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-12-15 16:54:14.301 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2020-12-15 16:54:14.301 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-12-15 16:54:14.301 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2020-12-15 16:54:14.301 Info, contrlr, The PC controller is a primary controller.
2020-12-15 16:54:14.301 Detail, Node215, Expected reply was received
2020-12-15 16:54:14.301 Detail, Node215, Message transaction complete
2020-12-15 16:54:14.301 Detail, contrlr, Removing current message
2020-12-15 16:54:14.301 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-12-15 16:54:14.305 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x00, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfa
2020-12-15 16:54:14.305 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2020-12-15 16:54:14.305 Info, contrlr, Serial API Version: 1.1
2020-12-15 16:54:14.305 Info, contrlr, Manufacturer ID: 0x0086
2020-12-15 16:54:14.305 Info, contrlr, Product Type: 0x0001
2020-12-15 16:54:14.305 Info, contrlr, Product ID: 0x005a
2020-12-15 16:54:14.305 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-12-15 16:54:14.305 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-12-15 16:54:14.305 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-12-15 16:54:14.306 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-12-15 16:54:14.306 Detail, Node001, Expected reply was received
2020-12-15 16:54:14.306 Detail, Node001, Message transaction complete
2020-12-15 16:54:14.306 Detail, contrlr, Removing current message
2020-12-15 16:54:14.306 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-12-15 16:54:14.307 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2020-12-15 16:54:14.307 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2020-12-15 16:54:14.307 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2020-12-15 16:54:14.307 Detail, Node172, Expected reply was received
2020-12-15 16:54:14.307 Detail, Node172, Message transaction complete
2020-12-15 16:54:14.308 Detail, contrlr, Removing current message
2020-12-15 16:54:14.308 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-12-15 16:54:14.364 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0xe6, 0xdd, 0xc7, 0xda, 0x2d, 0x8d, 0x72, 0x6e, 0x52, 0x1d, 0x82, 0xdb, 0x5a, 0xa7, 0xa1, 0x6a, 0x25, 0xe0, 0x07, 0x60, 0x0c, 0x6e, 0xa9, 0xef, 0xc7, 0xa5, 0xdc, 0x32, 0x13, 0x03, 0x9c, 0x53, 0x89
2020-12-15 16:54:14.364 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2020-12-15 16:54:14.364 Detail, Node032, Expected reply was received
2020-12-15 16:54:14.364 Detail, Node032, Message transaction complete
2020-12-15 16:54:14.364 Detail, contrlr, Removing current message
2020-12-15 16:54:14.364 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-12-15 16:54:14.468 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc5
2020-12-15 16:54:14.469 Info, mgr, Driver with Home ID of 0xe293f9a2 is now ready.
2020-12-15 16:54:14.470 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-12-15 16:54:14.470 Info, contrlr, Node 001 - Known
2020-12-15 16:54:14.470 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-12-15 16:54:14.470 Detail, Node001, QueryStage_CacheLoad
2020-12-15 16:54:14.470 Info, Node001, Node Identity Codes: 0086:0001:005a
2020-12-15 16:54:14.470 Detail, Node001, QueryStage_Associations
2020-12-15 16:54:14.470 Detail, Node001, QueryStage_Neighbors
2020-12-15 16:54:14.470 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2020-12-15 16:54:14.470 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-12-15 16:54:14.470 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2020-12-15 16:54:14.470 Detail, Expected reply was received
2020-12-15 16:54:14.470 Detail, Message transaction complete
2020-12-15 16:54:14.470 Detail, contrlr, Removing current message
2020-12-15 16:54:14.470 Detail, Node001, Notification: DriverReady
2020-12-15 16:54:14.476 Detail, Node001, Notification: NodeAdded
2020-12-15 16:54:14.482 Detail, Node001, Notification: NodeProtocolInfo
2020-12-15 16:54:14.488 Detail, Node001, Notification: EssentialNodeQueriesComplete
2020-12-15 16:54:14.493 Detail, Node001, Notification: ValueAdded
2020-12-15 16:54:14.499 Detail, Node001, Notification: NodeNaming
2020-12-15 16:54:14.505 Detail,
2020-12-15 16:54:14.505 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-12-15 16:54:14.506 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x96, 0x0f, 0x64
2020-12-15 16:54:14.507 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-12-15 16:54:14.507 Detail, Node015, Expected reply was received
2020-12-15 16:54:14.507 Detail, Node015, Message transaction complete
2020-12-15 16:54:14.507 Detail, contrlr, Removing current message
2020-12-15 16:54:14.507 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-12-15 16:54:14.508 Detail, contrlr, Removing current message
2020-12-15 16:54:14.508 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-12-15 16:54:14.519 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2020-12-15 16:54:14.519 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-12-15 16:54:14.519 Info, Node001, Neighbors of this node are:
2020-12-15 16:54:14.519 Info, Node001, (none reported)
2020-12-15 16:54:14.519 Detail, Expected reply was received
2020-12-15 16:54:14.519 Detail, Message transaction complete
2020-12-15 16:54:14.519 Detail, Node001, Removing current message
2020-12-15 16:54:14.519 Detail, Node001, Query Stage Complete (Neighbors)
2020-12-15 16:54:14.519 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-12-15 16:54:14.519 Detail, Node001, QueryStage_Session
2020-12-15 16:54:14.519 Detail, Node001, QueryStage_Dynamic
2020-12-15 16:54:14.519 Detail, Node001, QueryStage_Configuration
2020-12-15 16:54:14.519 Detail, Node001, QueryStage_Complete
2020-12-15 16:54:14.519 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-12-15 16:54:14.519 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2020-12-15 16:54:14.519 Info, Node query processing complete.
2020-12-15 16:54:14.519 Detail, Node001, Notification: NodeQueriesComplete
2020-12-15 16:54:14.525 Detail, contrlr, Notification: AllNodesQueried
2020-12-15 16:54:22.634 Detail, Queuing (Controller) Add Device
2020-12-15 16:54:22.635 Info, Add Device
2020-12-15 16:54:22.635 Detail, contrlr, Queuing (Command) ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2020-12-15 16:54:22.635 Detail, Notification: ControllerCommand - Starting
2020-12-15 16:54:22.636 Info, contrlr, Sending (Command) message (Callback ID=0x0a, Expected Reply=0x4a) - ControllerCommand_AddDevice: 0x01, 0x05, 0x00, 0x4a, 0xc1, 0x0a, 0x7b
2020-12-15 16:54:22.638 Detail, contrlr, Received: 0x01, 0x07, 0x00, 0x4a, 0x0a, 0x01, 0x00, 0x00, 0xb9
2020-12-15 16:54:22.639 Info, contrlr, FUNC_ID_ZW_ADD_NODE_TO_NETWORK:
2020-12-15 16:54:22.639 Info, contrlr, ADD_NODE_STATUS_LEARN_READY
2020-12-15 16:54:22.639 Detail, Node001, Expected callbackId was received
2020-12-15 16:54:22.639 Detail, Node001, Expected reply was received
2020-12-15 16:54:22.639 Detail, Node001, Message transaction complete
2020-12-15 16:54:22.639 Detail, contrlr, Removing current message
2020-12-15 16:54:22.639 Detail, Notification: ControllerCommand - Waiting
2020-12-15 16:54:22.639 Info, WriteNextMsg Controller nothing to do
This is the log after I pressed “Add note”.
The Z-Wave integration was set up with the integration tab and not with the configuration.yaml. I dont know what to do anymore. Maybe someone has an idea? Could it be that the Shutter is broken? Also the Z-Wave PC Controller program on my windows pc does not find the note…
Thanks and have a nice evening.
