Hi Community !
My haos versions are Home Assistant OS 8.1, supervisor-2022.05.3 and core-2022.5.5.
I’m using a smart implant Fibaro FGBS-222 to control 2 garage doors.
I have set Parameter 20 and Parameter 21 to “Normally closed alarm input”.
On this device, through Home Assistant, I can’t separate inputs from outputs.
In the configuration panel, local protection configuration shows “NoOperationPossible” for both garage door. But, in fact, it doesn’t work.
I tried to set this parameter through the developer tools ans api, but the following doesn’t work too :
“service: zwave_js.invoke_cc_api
command_class: 117
endpoint: 6
method_name: set
parameters:
- NoOperationPossible
device_id: XXXXXXXXXX”
There is an issue with parameters…
What is the way to change this setting?
Any idea ?
Thank you in advance for your help.
