Fibaro smoke detector (FGSD002) false alarm
Does anyone else have issues with false alarms on the Fibaro Smoke Detector?
When they where connected to Telldus, the bedroom smoke detector always started beeping for no reason. After moving them to HA, I have the same problem on the one in the livingroom.
As this almost always happens when I’m not at home, it’s kinda annoying to debug. The Z-wave log doesn’t say very much.
I leaved home about 08:30 today. No alarm then. My girlfriend took the alarm down when she got home, so it reports burglar 13:26. There has been some event at 09:05 and 09:19. The wakeup should be every 6 hours, so I guess the alarm started 09:19, as it shouldn’t have a reason for waking up then…?
All my smokedetectors are also in the same group, with broadcast turned on. In theory it should trigger all my smoke detectors if I understand the docs correct, but I haven’t tested this yet. On this event, no other smoke detectors was triggered.
2018-02-05 07:49:35.415 Detail, Node019, Notification: Notification - Node Asleep
2018-02-05 09:05:57.095 Detail, Node019,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x13, 0x06, 0x31, 0x05, 0x01, 0x22, 0x00, 0xc0, 0x35
2018-02-05 09:05:57.095 Info, Node019, Received SensorMultiLevel report from node 19, instance 1, Temperature: value=19.2C
2018-02-05 09:05:57.095 Detail, Node019, Refreshed Value: old value=20.2, new value=19.2, type=decimal
2018-02-05 09:05:57.095 Detail, Node019, Changes to this value are not verified
2018-02-05 09:05:57.095 Detail, Node019, Notification: ValueChanged
2018-02-05 09:19:27.759 Detail, Node019,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x13, 0x06, 0x31, 0x05, 0x01, 0x22, 0x00, 0xca, 0x3f
2018-02-05 09:19:27.759 Info, Node019, Received SensorMultiLevel report from node 19, instance 1, Temperature: value=20.2C
2018-02-05 09:19:27.759 Detail, Node019, Refreshed Value: old value=19.2, new value=20.2, type=decimal
2018-02-05 09:19:27.759 Detail, Node019, Changes to this value are not verified
2018-02-05 09:19:27.759 Detail, Node019, Notification: ValueChanged
2018-02-05 13:26:04.382 Detail, Node019,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x13, 0x02, 0x98, 0x40, 0x3a
2018-02-05 13:26:04.382 Info, Node019, Received SecurityCmd_NonceGet from node 19
2018-02-05 13:26:04.383 Info, Node019, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x13, 0x0a, 0x98, 0x80, 0xac, 0x12, 0x3c, 0xd0, 0x1b, 0x61, 0x78, 0x8b, 0x05, 0x01, 0x23:
2018-02-05 13:26:04.577 Detail, Node019,   Received: 0x01, 0x23, 0x00, 0x04, 0x00, 0x13, 0x1d, 0x98, 0x81, 0x7d, 0xad, 0xe9, 0xb3, 0x25, 0xa3, 0xe9, 0x3b, 0x89, 0xad, 0xa3, 0xd5, 0x9c, 0xcb, 0xc9, 0x43, 0x68, 0x84, 0xac, 0x12, 0x7f, 0xbc, 0x1a, 0x98, 0xbb, 0x4b, 0x8a, 0xf7
2018-02-05 13:26:04.578 Detail, Node019, Decrypted Packet: 0x00, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x07, 0x03, 0x00
2018-02-05 13:26:04.578 Info, Node019, Received Alarm report: type=0, level=0, sensorSrcID=0, type:Burglar event:3, status=255
2018-02-05 13:26:04.578 Detail, Node019, Refreshed Value: old value=0, new value=0, type=byte
2018-02-05 13:26:04.578 Detail, Node019, Changes to this value are not verified
2018-02-05 13:26:04.578 Detail, Node019, Initial read of value
2018-02-05 13:26:04.578 Detail, Node019, Notification: ValueChanged
2018-02-05 13:26:04.588 Detail, Node019, Notification: ValueChanged
2018-02-05 13:26:04.593 Detail, Node019, Notification: ValueChanged
2018-02-05 13:26:04.596 Detail, Node019, Notification: ValueChanged
2018-02-05 13:26:04.667 Detail, Node019,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x13, 0x02, 0x98, 0x40, 0x3a
2018-02-05 13:26:04.667 Info, Node019, Received SecurityCmd_NonceGet from node 19
2018-02-05 13:26:04.667 Info, Node019, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x13, 0x0a, 0x98, 0x80, 0x51, 0xba, 0xbb, 0x4f, 0x96, 0x31, 0xd6, 0x4c, 0x05, 0x01, 0xda:
2018-02-05 13:26:04.867 Detail, Node019,   Received: 0x01, 0x21, 0x00, 0x04, 0x00, 0x13, 0x1b, 0x98, 0x81, 0x5e, 0xee, 0xa6, 0x2a, 0xf6, 0x11, 0x03, 0xf3, 0x09, 0xbf, 0x55, 0xe5, 0xfc, 0x52, 0x1d, 0xe8, 0x51, 0x0a, 0xd2, 0xad, 0x46, 0x87, 0x78, 0x72, 0x1c, 0x4e
2018-02-05 13:26:04.867 Detail, Node019, Decrypted Packet: 0x00, 0x9c, 0x02, 0x13, 0x00, 0xff, 0x00, 0x00
2018-02-05 13:26:04.867 Detail, Node019, Initial read of value
2018-02-05 13:26:04.867 Info, Node019, Received alarm state report from node 19: General = 255
2018-02-05 13:26:04.867 Detail, Node019, Notification: ValueChanged
