FIBARO System FGMS001 Motion Sensor Sensor_11_0 where are my other sensors?
Hi Guys,
I’m probably being very dense here but I can’t find where my other (temp and lux) sensors have gone, well that’s not strictly true I think I know where they are I just don’t know how to access them :frowning: I’ve just upgraded from 44.1 to 48 and my zwave is not going well. While ozwcp can see and access all parts of my FGMS HA cannot, it now only see the motion sensor above, the other sensors are buried under the nodes button and don’t show up in the states page or in the frontend.
The node info button shows…
New_entity_id: Zwave.Fibaro_system_fgms001_motion_sensor
Node_id: 11
Node_name: FIBARO System FGMS001 Motion Sensor
Old_entity_id: Zwave.Fibaro_system_fgms001_motion_sensor_11
… which means HA should be using the new entity id’s I think? but HA is still using FIBARO_System_FGMS001_Motion_Sensor_Sensor_11_0 for motion and it’s lost the others (used to show up as FIBARO_System_FGMS001_Motion_Sensor_Sensor_temp_11_1 and FIBARO_System_FGMS001_Motion_Sensor_Sensor_lux_11_3)
Any ideas?
As of 0.48 the entity IDs changed for Z-wave devices.
See: https://home-assistant.io/blog/2017/07/02/release-48/#
Look for breaking changes.
That’s kind of my point they haven’t changed! However I’ve finally manged to get something that while it doesn’t work actually shows a new node with similar numbers i.e. temp_12_1 etc, however there are no results from any of the three sensors, so one step forwards and 3 back :frowning:
