I have problems with my newest z-wave device: Fibaro Wall Plug Gen5 (NODE 10)
Adding to HA works good and I see all switches and sensors from this node in Home Assistant.
But I have problems controlling this device via the UI properly. Sometimes is does not respond, or the feedback in the HA UI is not correct.
It is about one meter away from the Z Wave stick, so I dont thing its an range issue.
I made a gif, because its hard to explain.
Thats the zwave log.
2017-08-14 23:01:05.653 Detail, Node004, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x04, 0x06, 0x31, 0x05, 0x03, 0x0a, 0x00, 0x00, 0xc8
2017-08-14 23:01:05.653 Info, Node004, Received SensorMultiLevel report from node 4, instance 1, Luminance: value=0lux
2017-08-14 23:01:05.653 Detail, Node004, Refreshed Value: old value=0, new value=0, type=decimal
2017-08-14 23:01:05.653 Detail, Node004, Changes to this value are not verified
2017-08-14 23:01:05.654 Detail, Node004, Notification: ValueChanged
2017-08-14 23:13:08.765 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2017-08-14 23:13:08.765 Info, Node010, SwitchBinary::Set - Setting node 10 to On
2017-08-14 23:13:08.766 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0xff, 0x25, 0xb4, 0xa5
2017-08-14 23:13:08.766 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xb5, 0x5a
2017-08-14 23:13:08.766 Info, Node010, Sending (Send) message (Callback ID=0xb4, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0xff, 0x25, 0xb4, 0xa5
2017-08-14 23:13:08.775 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:13:08.793 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:13:08.815 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xb4, 0x00, 0x00, 0x05, 0x5a
2017-08-14 23:13:08.816 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xb4 received (expected 0xb4)
2017-08-14 23:13:08.816 Info, Node010, Request RTT 49 Average Request RTT 66
2017-08-14 23:13:08.816 Detail, Expected callbackId was received
2017-08-14 23:13:08.816 Detail, Expected reply was received
2017-08-14 23:13:08.816 Detail, Message transaction complete
2017-08-14 23:13:08.816 Detail, Node010, Removing current message
2017-08-14 23:13:08.817 Info, Node010, Sending (Send) message (Callback ID=0xb5, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xb5, 0x5a
2017-08-14 23:13:08.825 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:13:08.826 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:13:09.566 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xb5, 0x00, 0x00, 0x4b, 0x15
2017-08-14 23:13:09.566 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xb5 received (expected 0xb5)
2017-08-14 23:13:09.566 Info, Node010, Request RTT 750 Average Request RTT 408
2017-08-14 23:13:09.566 Detail, Expected callbackId was received
2017-08-14 23:13:09.644 Detail, Node010, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0a, 0x03, 0x25, 0x03, 0xff, 0x22
2017-08-14 23:13:09.644 Info, Node010, Response RTT 828 Average Response RTT 493
2017-08-14 23:13:09.644 Info, Node010, Received SwitchBinary report from node 10: level=On
2017-08-14 23:13:09.644 Detail, Node010, Refreshed Value: old value=false, new value=true, type=bool
2017-08-14 23:13:09.644 Detail, Node010, Changes to this value are not verified
2017-08-14 23:13:09.644 Detail, Node010, Expected reply and command class was received
2017-08-14 23:13:09.644 Detail, Node010, Message transaction complete
2017-08-14 23:13:09.645 Detail,
2017-08-14 23:13:09.645 Detail, Node010, Removing current message
2017-08-14 23:13:09.645 Detail, Node010, Notification: ValueChanged
2017-08-14 23:13:09.693 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x53, 0xba
2017-08-14 23:13:09.693 Info, Node010, Received SensorMultiLevel report from node 10, instance 1, Power: value=8.3W
2017-08-14 23:13:09.693 Detail, Node010, Refreshed Value: old value=0.0, new value=8.3, type=decimal
2017-08-14 23:13:09.693 Detail, Node010, Changes to this value are not verified
2017-08-14 23:13:09.693 Detail, Node010, Notification: ValueChanged
2017-08-14 23:13:21.320 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - False
2017-08-14 23:13:21.321 Info, Node010, SwitchBinary::Set - Setting node 10 to Off
2017-08-14 23:13:21.321 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0x00, 0x25, 0xb6, 0x58
2017-08-14 23:13:21.321 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xb7, 0x58
2017-08-14 23:13:21.321 Info, Node010, Sending (Send) message (Callback ID=0xb6, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0x00, 0x25, 0xb6, 0x58
2017-08-14 23:13:21.331 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:13:21.332 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:13:21.370 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xb6, 0x00, 0x00, 0x04, 0x59
2017-08-14 23:13:21.371 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xb6 received (expected 0xb6)
2017-08-14 23:13:21.371 Info, Node010, Request RTT 49 Average Request RTT 228
2017-08-14 23:13:21.371 Detail, Expected callbackId was received
2017-08-14 23:13:21.371 Detail, Expected reply was received
2017-08-14 23:13:21.371 Detail, Message transaction complete
2017-08-14 23:13:21.371 Detail, Node010, Removing current message
2017-08-14 23:13:21.372 Detail,
2017-08-14 23:13:21.372 Info, Node010, Sending (Send) message (Callback ID=0xb7, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xb7, 0x58
2017-08-14 23:13:21.381 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:13:21.382 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:13:21.581 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xb7, 0x00, 0x00, 0x14, 0x48
2017-08-14 23:13:21.581 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xb7 received (expected 0xb7)
2017-08-14 23:13:21.581 Info, Node010, Request RTT 209 Average Request RTT 218
2017-08-14 23:13:21.581 Detail, Expected callbackId was received
2017-08-14 23:13:22.125 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe9
2017-08-14 23:13:22.125 Info, Node010, Response RTT 754 Average Response RTT 623
2017-08-14 23:13:22.125 Info, Node010, Received SensorMultiLevel report from node 10, instance 1, Power: value=0.0W
2017-08-14 23:13:22.125 Detail, Node010, Refreshed Value: old value=8.3, new value=0.0, type=decimal
2017-08-14 23:13:22.125 Detail, Node010, Changes to this value are not verified
2017-08-14 23:13:22.125 Detail, Node010, Notification: ValueChanged
2017-08-14 23:13:31.371 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-08-14 23:13:31.372 Detail, Node010, Removing current message
2017-08-14 23:13:31.372 Detail, Node010, Notification: Notification - TimeOut
2017-08-14 23:13:49.586 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - False
2017-08-14 23:13:49.586 Info, Node010, SwitchBinary::Set - Setting node 10 to Off
2017-08-14 23:13:49.587 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0x00, 0x25, 0xb8, 0x56
2017-08-14 23:13:49.587 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xb9, 0x56
2017-08-14 23:13:49.587 Info, Node010, Sending (Send) message (Callback ID=0xb8, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0x00, 0x25, 0xb8, 0x56
2017-08-14 23:13:49.596 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:13:49.596 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:13:49.636 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xb8, 0x00, 0x00, 0x05, 0x56
2017-08-14 23:13:49.636 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xb8 received (expected 0xb8)
2017-08-14 23:13:49.637 Info, Node010, Request RTT 49 Average Request RTT 133
2017-08-14 23:13:49.637 Detail, Expected callbackId was received
2017-08-14 23:13:49.637 Detail, Expected reply was received
2017-08-14 23:13:49.637 Detail, Message transaction complete
2017-08-14 23:13:49.637 Detail, Node010, Removing current message
2017-08-14 23:13:49.637 Info, Node010, Sending (Send) message (Callback ID=0xb9, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xb9, 0x56
2017-08-14 23:13:49.646 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:13:49.647 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:13:49.711 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xb9, 0x00, 0x00, 0x07, 0x55
2017-08-14 23:13:49.711 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xb9 received (expected 0xb9)
2017-08-14 23:13:49.711 Info, Node010, Request RTT 73 Average Request RTT 103
2017-08-14 23:13:49.711 Detail, Expected callbackId was received
2017-08-14 23:13:49.783 Detail, Node010, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0a, 0x03, 0x25, 0x03, 0x00, 0xdd
2017-08-14 23:13:49.784 Info, Node010, Response RTT 146 Average Response RTT 384
2017-08-14 23:13:49.784 Info, Node010, Received SwitchBinary report from node 10: level=Off
2017-08-14 23:13:49.784 Detail, Node010, Refreshed Value: old value=true, new value=false, type=bool
2017-08-14 23:13:49.784 Detail, Node010, Changes to this value are not verified
2017-08-14 23:13:49.784 Detail, Node010, Expected reply and command class was received
2017-08-14 23:13:49.784 Detail, Node010, Message transaction complete
2017-08-14 23:13:49.784 Detail, Node010, Removing current message
2017-08-14 23:13:49.784 Detail, Node010, Notification: ValueChanged
2017-08-14 23:14:02.676 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2017-08-14 23:14:02.676 Info, Node010, SwitchBinary::Set - Setting node 10 to On
2017-08-14 23:14:02.676 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0xff, 0x25, 0xba, 0xab
2017-08-14 23:14:02.676 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xbb, 0x54
2017-08-14 23:14:02.677 Detail,
2017-08-14 23:14:02.677 Info, Node010, Sending (Send) message (Callback ID=0xba, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0xff, 0x25, 0xba, 0xab
2017-08-14 23:14:02.686 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:14:02.687 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:14:02.726 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xba, 0x00, 0x00, 0x05, 0x54
2017-08-14 23:14:02.726 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xba received (expected 0xba)
2017-08-14 23:14:02.726 Info, Node010, Request RTT 49 Average Request RTT 76
2017-08-14 23:14:02.726 Detail, Expected callbackId was received
2017-08-14 23:14:02.726 Detail, Expected reply was received
2017-08-14 23:14:02.727 Detail, Message transaction complete
2017-08-14 23:14:02.727 Detail, Node010, Removing current message
2017-08-14 23:14:02.727 Info, Node010, Sending (Send) message (Callback ID=0xbb, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xbb, 0x54
2017-08-14 23:14:02.736 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:14:02.736 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:14:03.000 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xbb, 0x00, 0x00, 0x1b, 0x4b
2017-08-14 23:14:03.000 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xbb received (expected 0xbb)
2017-08-14 23:14:03.001 Info, Node010, Request RTT 274 Average Request RTT 175
2017-08-14 23:14:03.001 Detail, Expected callbackId was received
2017-08-14 23:14:03.525 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x52, 0xbb
2017-08-14 23:14:03.526 Detail,
2017-08-14 23:14:03.526 Info, Node010, Response RTT 799 Average Response RTT 591
2017-08-14 23:14:03.526 Info, Node010, Received SensorMultiLevel report from node 10, instance 1, Power: value=8.2W
2017-08-14 23:14:03.526 Detail, Node010, Refreshed Value: old value=0.0, new value=8.2, type=decimal
2017-08-14 23:14:03.526 Detail, Node010, Changes to this value are not verified
2017-08-14 23:14:03.526 Detail, Node010, Notification: ValueChanged
2017-08-14 23:14:12.727 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-08-14 23:14:12.727 Detail, Node010, Removing current message
2017-08-14 23:14:12.728 Detail, Node010, Notification: Notification - TimeOut
2017-08-14 23:14:29.804 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2017-08-14 23:14:29.804 Info, Node010, SwitchBinary::Set - Setting node 10 to On
2017-08-14 23:14:29.804 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0xff, 0x25, 0xbc, 0xad
2017-08-14 23:14:29.804 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xbd, 0x52
2017-08-14 23:14:29.804 Info, Node010, Sending (Send) message (Callback ID=0xbc, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0xff, 0x25, 0xbc, 0xad
2017-08-14 23:14:29.813 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:14:29.813 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:14:29.895 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xbc, 0x00, 0x00, 0x09, 0x5e
2017-08-14 23:14:29.896 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xbc received (expected 0xbc)
2017-08-14 23:14:29.896 Info, Node010, Request RTT 91 Average Request RTT 133
2017-08-14 23:14:29.896 Detail, Expected callbackId was received
2017-08-14 23:14:29.896 Detail, Expected reply was received
2017-08-14 23:14:29.896 Detail, Message transaction complete
2017-08-14 23:14:29.896 Detail, Node010, Removing current message
2017-08-14 23:14:29.896 Info, Node010, Sending (Send) message (Callback ID=0xbd, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xbd, 0x52
2017-08-14 23:14:29.905 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:14:29.906 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:14:29.948 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xbd, 0x00, 0x00, 0x05, 0x53
2017-08-14 23:14:29.948 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xbd received (expected 0xbd)
2017-08-14 23:14:29.948 Info, Node010, Request RTT 51 Average Request RTT 92
2017-08-14 23:14:29.948 Detail, Expected callbackId was received
2017-08-14 23:14:30.023 Detail, Node010, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0a, 0x03, 0x25, 0x03, 0xff, 0x22
2017-08-14 23:14:30.024 Detail,
2017-08-14 23:14:30.024 Info, Node010, Response RTT 128 Average Response RTT 359
2017-08-14 23:14:30.024 Info, Node010, Received SwitchBinary report from node 10: level=On
2017-08-14 23:14:30.024 Detail, Node010, Refreshed Value: old value=false, new value=true, type=bool
2017-08-14 23:14:30.024 Detail, Node010, Changes to this value are not verified
2017-08-14 23:14:30.024 Detail, Node010, Expected reply and command class was received
2017-08-14 23:14:30.024 Detail, Node010, Message transaction complete
2017-08-14 23:14:30.024 Detail, Node010, Removing current message
2017-08-14 23:14:30.024 Detail, Node010, Notification: ValueChanged
2017-08-14 23:14:33.551 Info, Node010, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - False
2017-08-14 23:14:33.552 Info, Node010, SwitchBinary::Set - Setting node 10 to Off
2017-08-14 23:14:33.552 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0x00, 0x25, 0xbe, 0x50
2017-08-14 23:14:33.552 Detail, Node010, Queuing (Send) SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xbf, 0x50
2017-08-14 23:14:33.552 Info, Node010, Sending (Send) message (Callback ID=0xbe, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=10): 0x01, 0x0a, 0x00, 0x13, 0x0a, 0x03, 0x25, 0x01, 0x00, 0x25, 0xbe, 0x50
2017-08-14 23:14:33.561 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:14:33.562 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:14:33.600 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xbe, 0x00, 0x00, 0x04, 0x51
2017-08-14 23:14:33.600 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xbe received (expected 0xbe)
2017-08-14 23:14:33.600 Info, Node010, Request RTT 48 Average Request RTT 70
2017-08-14 23:14:33.600 Detail, Expected callbackId was received
2017-08-14 23:14:33.601 Detail, Expected reply was received
2017-08-14 23:14:33.601 Detail, Message transaction complete
2017-08-14 23:14:33.601 Detail, Node010, Removing current message
2017-08-14 23:14:33.601 Info, Node010, Sending (Send) message (Callback ID=0xbf, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=10): 0x01, 0x09, 0x00, 0x13, 0x0a, 0x02, 0x25, 0x02, 0x25, 0xbf, 0x50
2017-08-14 23:14:33.610 Detail, Node010, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:14:33.610 Detail, Node010, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:14:33.839 Detail, Node010, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0a, 0x03, 0x25, 0x03, 0x00, 0xdd
2017-08-14 23:14:33.839 Info, Node010, Response RTT 237 Average Response RTT 298
2017-08-14 23:14:33.839 Info, Node010, Received SwitchBinary report from node 10: level=Off
2017-08-14 23:14:33.839 Detail, Node010, Refreshed Value: old value=true, new value=false, type=bool
2017-08-14 23:14:33.839 Detail, Node010, Changes to this value are not verified
2017-08-14 23:14:33.839 Detail, Node010, Notification: ValueChanged
2017-08-14 23:14:34.765 Detail, Node010, Received: 0x01, 0x07, 0x00, 0x13, 0xbf, 0x00, 0x00, 0x74, 0x20
2017-08-14 23:14:34.766 Detail, Node010, ZW_SEND_DATA Request with callback ID 0xbf received (expected 0xbf)
2017-08-14 23:14:34.766 Info, Node010, Request RTT 1164 Average Request RTT 617
2017-08-14 23:14:34.766 Detail, Expected callbackId was received
2017-08-14 23:14:35.033 Detail, Node010, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x0a, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe9
2017-08-14 23:14:35.033 Info, Node010, Response RTT 1433 Average Response RTT 865
2017-08-14 23:14:35.034 Info, Node010, Received SensorMultiLevel report from node 10, instance 1, Power: value=0.0W
2017-08-14 23:14:35.034 Detail, Node010, Refreshed Value: old value=8.2, new value=0.0, type=decimal
2017-08-14 23:14:35.034 Detail, Node010, Changes to this value are not verified
2017-08-14 23:14:35.034 Detail, Node010, Notification: ValueChanged
2017-08-14 23:14:43.601 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-08-14 23:14:43.602 Detail, Node010, Removing current message
2017-08-14 23:14:43.602 Detail, Node010, Notification: Notification - TimeOut
2017-08-14 23:18:00.662 Detail, Node004, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x04, 0x02, 0x84, 0x07, 0x76
2017-08-14 23:18:00.663 Detail,
2017-08-14 23:18:00.663 Info, Node004, Received Wakeup Notification from node 4
2017-08-14 23:18:00.663 Info, Node004, Node 4 has been marked as awake
2017-08-14 23:18:00.663 Detail, Node004, Queuing (Controller) Request Node Neighbor Update
2017-08-14 23:18:00.663 Detail, Node004, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x84, 0x08, 0x25, 0xc0, 0x8a
2017-08-14 23:18:00.663 Detail, Node004, Notification: Notification - Node Awake
2017-08-14 23:18:00.669 Info, Requesting Neighbor Update for node 4
2017-08-14 23:18:00.669 Detail, Node004, Queuing (Command) ControllerCommand_RequestNodeNeighborUpdate (Node=4): 0x01, 0x05, 0x00, 0x48, 0x04, 0xc1, 0x77
2017-08-14 23:18:00.669 Detail, Notification: ControllerCommand - Starting
2017-08-14 23:18:00.670 Detail,
2017-08-14 23:18:00.670 Info, Node004, Sending (Command) message (Callback ID=0xc1, Expected Reply=0x48) - ControllerCommand_RequestNodeNeighborUpdate (Node=4): 0x01, 0x05, 0x00, 0x48, 0x04, 0xc1, 0x77
2017-08-14 23:18:00.724 Detail, Node004, Received: 0x01, 0x05, 0x00, 0x48, 0xc1, 0x21, 0x52
2017-08-14 23:18:00.724 Info, Node004, REQUEST_NEIGHBOR_UPDATE_STARTED
2017-08-14 23:18:00.724 Detail, Node033, Expected callbackId was received
2017-08-14 23:18:00.724 Detail, Node033, Expected reply was received
2017-08-14 23:18:00.724 Detail, Node033, Message transaction complete
2017-08-14 23:18:00.724 Detail, Node004, Removing current message
2017-08-14 23:18:00.724 Detail, Notification: ControllerCommand - InProgress
2017-08-14 23:18:01.411 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0xc1, 0x21, 0x52
2017-08-14 23:18:01.411 Info, REQUEST_NEIGHBOR_UPDATE_STARTED
2017-08-14 23:18:01.411 Detail, Notification: ControllerCommand - InProgress
2017-08-14 23:18:02.270 Detail, Received: 0x01, 0x05, 0x00, 0x48, 0xc1, 0x22, 0x51
2017-08-14 23:18:02.270 Info, REQUEST_NEIGHBOR_UPDATE_DONE
2017-08-14 23:18:02.270 Detail, Requesting routing info (neighbor list) for Node 4
2017-08-14 23:18:02.270 Detail, Node004, Queuing (Command) Get Routing Info (Node=4): 0x01, 0x07, 0x00, 0x80, 0x04, 0x00, 0x00, 0x03, 0x7f
2017-08-14 23:18:02.270 Detail, Notification: ControllerCommand - Completed
2017-08-14 23:18:02.271 Detail,
2017-08-14 23:18:02.271 Info, Node004, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=4): 0x01, 0x07, 0x00, 0x80, 0x04, 0x00, 0x00, 0x03, 0x7f
2017-08-14 23:18:02.279 Detail, Node004, Received: 0x01, 0x20, 0x01, 0x80, 0x96, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xc8
2017-08-14 23:18:02.279 Info, Node004, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2017-08-14 23:18:02.279 Info, Node004, Neighbors of this node are:
2017-08-14 23:18:02.279 Info, Node004, Node 2
2017-08-14 23:18:02.279 Info, Node004, Node 3
2017-08-14 23:18:02.279 Info, Node004, Node 5
2017-08-14 23:18:02.279 Info, Node004, Node 8
2017-08-14 23:18:02.279 Detail, Expected reply was received
2017-08-14 23:18:02.279 Detail, Message transaction complete
2017-08-14 23:18:02.279 Detail, Node004, Removing current message
2017-08-14 23:18:02.279 Info, Node004, Sending (WakeUp) message (Callback ID=0xc0, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=4): 0x01, 0x09, 0x00, 0x13, 0x04, 0x02, 0x84, 0x08, 0x25, 0xc0, 0x8a
2017-08-14 23:18:02.405 Detail, Node004, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-14 23:18:02.405 Detail, Node004, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-14 23:18:02.445 Detail, Node004, Received: 0x01, 0x07, 0x00, 0x13, 0xc0, 0x00, 0x00, 0x11, 0x3a
2017-08-14 23:18:02.445 Detail, Node004, ZW_SEND_DATA Request with callback ID 0xc0 received (expected 0xc0)
2017-08-14 23:18:02.445 Info, Node004, Request RTT 166 Average Request RTT 135
2017-08-14 23:18:02.446 Info, Node004, Node 4 has been marked as asleep
2017-08-14 23:18:02.446 Detail, Expected callbackId was received
2017-08-14 23:18:02.446 Detail, Expected reply was received
2017-08-14 23:18:02.446 Detail, Message transaction complete
2017-08-14 23:18:02.446 Detail, Node004, Removing current message
2017-08-14 23:18:02.446 Detail, Node004, Notification: Notification - Node Asleep
