Fibaro Wall Plug: Operates once, then does not update
I just purchased some Fibaro Wall Plugs (Model FGWPB-121). They have been included just fine, showing up as FIBARO System Unknown: type=1401, id=2000 with multiple sensors and a single switch.
If I use Home Assistant to turn the plug on, it will turn on once. But the status will not update, it will continue to say that it is off. The only way I can get the switch status to update is if I refresh the node in the Z-wave configuration. If I manually shut off the switch, homeassistant is capable of turning it back on, and it won’t update its status or turn it off.
I tried adding secured, and I tried adding in unsecured.
Any one have any suggestions?
Further troubleshooting on this, if I manually refresh the node it will show the correct sensor state. I can then issue another control, and it will shut off if it was on, but then it continues to show that it is on, even though it is off. Then a node refresh will fix it… guessing I’ll have to take this up with the openzwave people…
I don’t have this type of device but on some of my other z wave devices (Aeotec switches) there is a setting that you can access via the z wave configuration section that switches the reporting type.
I think I had to change mine to “hail” to get it to report back the state to the controller.
Again I’m not sure if yours is like that but it may be a start to help investigate a solution.
Hmm thanks for the information, I read the whole menu and found no options for changing reporting type. I found a marginal work around in the Z-Wave Control Panel of Home Assistant for the switch node I set “polling intensity” to a 2 and now the switch will update withing about 20 seconds, which is ok for my applications.
I’m going to continue hunting around for this. In the Z-wave logs there is an error message after each control saying a response expected wasn’t received giving up on the control.
2018-11-26 18:29:57.585 Info, Node017, Value::Set - COMMAND_CLASS_SWITCH_BINARY - Switch - 0 - 1 - True
2018-11-26 18:29:57.590 Info, Node017, SwitchBinary::Set - Setting node 17 to On
2018-11-26 18:29:57.590 Detail, Node017, Setting Encryption Flag on Message For Command Class COMMAND_CLASS_SWITCH_BINARY
2018-11-26 18:29:57.590 Detail, Node017, Queuing (Send) SwitchBinaryCmd_Set (Node=17): 0x01, 0x0a, 0x00, 0x13, 0x11, 0x03, 0x25, 0x01, 0xff, 0x25, 0x74, 0x7e
2018-11-26 18:29:57.590 Detail, Node017, Queuing (Send) SwitchBinaryCmd_Get (Node=17): 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x25, 0x02, 0x25, 0x75, 0x81
2018-11-26 18:29:57.590 Info, Node017, Processing (Send) Nonce Request message (Callback ID=0x74, Expected Reply=0x13)
2018-11-26 18:29:57.590 Info, Node017, Sending (Send) message (Callback ID=0x74, Expected Reply=0x13) - Nonce_Get(SwitchBinaryCmd_Set) - 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x98, 0x40, 0x05, 0x02:
2018-11-26 18:29:57.598 Detail, Node017,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-26 18:29:57.600 Detail, Node017,   ZW_SEND_DATA delivered to Z-Wave stack
2018-11-26 18:29:57.618 Detail, Node017,   Received: 0x01, 0x18, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x3f
2018-11-26 18:29:57.618 Detail, Node017,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2018-11-26 18:29:57.619 Info, Node017, Request RTT 27 Average Request RTT 97
2018-11-26 18:29:57.637 Detail, Node017,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x11, 0x0a, 0x98, 0x80, 0xe3, 0xe8, 0xbe, 0xec, 0x90, 0xd0, 0x32, 0xc0, 0xc9, 0x00, 0xc8
2018-11-26 18:29:57.637 Info, Node017, Received SecurityCmd_NonceReport from node 17
2018-11-26 18:29:57.637 Info, Node017, Sending (Send) message (Callback ID=0x76, Expected Reply=0x13) - SwitchBinaryCmd_Set (Node=17): 0x01, 0x0a, 0x00, 0x13, 0x11, 0x03, 0x25, 0x01, 0xff, 0x25, 0x76, 0x7c
2018-11-26 18:29:57.648 Detail, Node017,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-26 18:29:57.648 Detail, Node017,   ZW_SEND_DATA delivered to Z-Wave stack
2018-11-26 18:29:57.670 Detail, Node017,   Received: 0x01, 0x18, 0x00, 0x13, 0x76, 0x00, 0x00, 0x03, 0x00, 0xca, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x4a
2018-11-26 18:29:57.670 Detail, Node017,   ZW_SEND_DATA Request with callback ID 0x76 received (expected 0x76)
2018-11-26 18:29:57.670 Info, Node017, Request RTT 79 Average Request RTT 88
2018-11-26 18:29:57.670 Detail,   Expected callbackId was received
2018-11-26 18:29:57.670 Detail,   Expected reply was received
2018-11-26 18:29:57.670 Detail,   Message transaction complete
2018-11-26 18:29:57.670 Detail, Node017, Removing current message
2018-11-26 18:29:57.671 Detail,
2018-11-26 18:29:57.671 Info, Node017, Processing (Send) Nonce Request message (Callback ID=0x75, Expected Reply=0x04)
2018-11-26 18:29:57.671 Info, Node017, Sending (Send) message (Callback ID=0x75, Expected Reply=0x04) - Nonce_Get(SwitchBinaryCmd_Get) - 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x98, 0x40, 0x05, 0x02:
2018-11-26 18:29:57.679 Detail, Node017,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-26 18:29:57.682 Detail, Node017,   ZW_SEND_DATA delivered to Z-Wave stack
2018-11-26 18:29:57.698 Detail, Node017,   Received: 0x01, 0x18, 0x00, 0x13, 0x02, 0x00, 0x00, 0x02, 0x00, 0xc9, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x3c
2018-11-26 18:29:57.698 Detail, Node017,   ZW_SEND_DATA Request with callback ID 0x02 received (expected 0x02)
2018-11-26 18:29:57.698 Info, Node017, Request RTT 27 Average Request RTT 57
2018-11-26 18:29:57.717 Detail, Node017,   Received: 0x01, 0x12, 0x00, 0x04, 0x00, 0x11, 0x0a, 0x98, 0x80, 0xca, 0x66, 0x54, 0xf3, 0xfa, 0x21, 0x1a, 0x70, 0xca, 0x00, 0x9a
2018-11-26 18:29:57.717 Info, Node017, Received SecurityCmd_NonceReport from node 17
2018-11-26 18:29:57.718 Info, Node017, Sending (Send) message (Callback ID=0x77, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=17): 0x01, 0x09, 0x00, 0x13, 0x11, 0x02, 0x25, 0x02, 0x25, 0x77, 0x83
2018-11-26 18:29:57.728 Detail, Node017,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-26 18:29:57.728 Detail, Node017,   ZW_SEND_DATA delivered to Z-Wave stack
2018-11-26 18:29:57.749 Detail, Node017,   Received: 0x01, 0x18, 0x00, 0x13, 0x77, 0x00, 0x00, 0x03, 0x00, 0xc6, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x47
2018-11-26 18:29:57.749 Detail, Node017,   ZW_SEND_DATA Request with callback ID 0x77 received (expected 0x77)
2018-11-26 18:29:57.749 Info, Node017, Request RTT 78 Average Request RTT 67
2018-11-26 18:29:57.749 Detail,   Expected callbackId was received
2018-11-26 18:29:57.768 Detail, Node017,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x11, 0x02, 0x98, 0x40, 0xc7, 0x00, 0xfd
2018-11-26 18:29:57.768 Info, Node017, Received SecurityCmd_NonceGet from node 17
2018-11-26 18:29:57.768 Info, NONCES: 0x57, 0x4d, 0x44, 0x32, 0xd5, 0x42, 0xd4, 0x38
2018-11-26 18:29:57.769 Info, NONCES: 0xb5, 0x6d, 0x20, 0x3f, 0x19, 0x70, 0xf9, 0xf1
2018-11-26 18:29:57.769 Info, NONCES: 0xf0, 0xc2, 0x1c, 0xfe, 0x52, 0xad, 0x0c, 0x74
2018-11-26 18:29:57.769 Info, NONCES: 0xea, 0x24, 0xaf, 0xc9, 0xcf, 0xaf, 0x6c, 0xfb
2018-11-26 18:29:57.769 Info, NONCES: 0xba, 0x7d, 0x94, 0xb8, 0x4c, 0x85, 0x19, 0x06
2018-11-26 18:29:57.769 Info, NONCES: 0x24, 0xfe, 0x83, 0x54, 0xe8, 0x34, 0xaa, 0xfe
2018-11-26 18:29:57.769 Info, NONCES: 0x28, 0x3a, 0x5a, 0x94, 0x69, 0x46, 0x4b, 0x39
2018-11-26 18:29:57.769 Info, NONCES: 0x18, 0x6e, 0xf0, 0xe1, 0xb8, 0x31, 0xfd, 0x7d
2018-11-26 18:29:57.769 Info, Node017, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x11, 0x0a, 0x98, 0x80, 0x24, 0xfe, 0x83, 0x54, 0xe8, 0x34, 0xaa, 0xfe, 0x05, 0x01, 0x7f:
2018-11-26 18:29:57.777 Detail, Node017,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-26 18:29:57.777 Detail, Node017,   ZW_SEND_DATA delivered to Z-Wave stack
2018-11-26 18:29:57.798 Detail, Node017,   Received: 0x01, 0x18, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0x00, 0xc6, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x30
2018-11-26 18:29:57.798 Detail, Node017,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-11-26 18:29:57.798 Info, Node017, Request RTT 126 Average Request RTT 96
2018-11-26 18:29:57.823 Detail, Node017,   Received: 0x01, 0x20, 0x00, 0x04, 0x00, 0x11, 0x18, 0x98, 0x81, 0xbf, 0xbb, 0x59, 0xdd, 0x02, 0x70, 0x93, 0x22, 0xd1, 0xf5, 0xe9, 0x1a, 0x28, 0x24, 0xac, 0xb8, 0x71, 0xdd, 0x9f, 0x11, 0x17, 0xda, 0xc6, 0x00, 0x6e
2018-11-26 18:29:57.823 Info, Raw: 0x98, 0x81, 0xbf, 0xbb, 0x59, 0xdd, 0x02, 0x70, 0x93, 0x22, 0xd1, 0xf5, 0xe9, 0x1a, 0x28, 0x24, 0xac, 0xb8, 0x71, 0xdd, 0x9f, 0x11, 0x17, 0xda, 0xc6
2018-11-26 18:29:57.823 Detail, Node017, Decrypted Packet: 0x00, 0x22, 0x01, 0x01, 0x02
2018-11-26 18:29:57.823 Info, Node017, Response RTT 152 Average Response RTT 299
2018-11-26 18:29:59.225 Detail, Node017,   Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x11, 0x02, 0x98, 0x40, 0xc6, 0x00, 0xfc
2018-11-26 18:29:59.226 Info, Node017, Received SecurityCmd_NonceGet from node 17
2018-11-26 18:29:59.226 Info, NONCES: 0x57, 0x4d, 0x44, 0x32, 0xd5, 0x42, 0xd4, 0x38
2018-11-26 18:29:59.226 Info, NONCES: 0xb5, 0x6d, 0x20, 0x3f, 0x19, 0x70, 0xf9, 0xf1
2018-11-26 18:29:59.226 Info, NONCES: 0xf0, 0xc2, 0x1c, 0xfe, 0x52, 0xad, 0x0c, 0x74
2018-11-26 18:29:59.226 Info, NONCES: 0xea, 0x24, 0xaf, 0xc9, 0xcf, 0xaf, 0x6c, 0xfb
2018-11-26 18:29:59.227 Info, NONCES: 0xba, 0x7d, 0x94, 0xb8, 0x4c, 0x85, 0x19, 0x06
2018-11-26 18:29:59.227 Info, NONCES: 0x24, 0xfe, 0x83, 0x54, 0xe8, 0x34, 0xaa, 0xfe
2018-11-26 18:29:59.227 Info, NONCES: 0xc8, 0x10, 0xee, 0x29, 0xfc, 0x90, 0x9e, 0x90
2018-11-26 18:29:59.227 Info, NONCES: 0x18, 0x6e, 0xf0, 0xe1, 0xb8, 0x31, 0xfd, 0x7d
2018-11-26 18:29:59.227 Info, Node017, Sending (Send) message (Callback ID=0x01, Expected Reply=0x04) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x11, 0x0a, 0x98, 0x80, 0xc8, 0x10, 0xee, 0x29, 0xfc, 0x90, 0x9e, 0x90, 0x05, 0x01, 0x87:
2018-11-26 18:29:59.235 Detail, Node017,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-11-26 18:29:59.236 Detail, Node017,   ZW_SEND_DATA delivered to Z-Wave stack
2018-11-26 18:29:59.255 Detail, Node017,   Received: 0x01, 0x18, 0x00, 0x13, 0x01, 0x00, 0x00, 0x02, 0x00, 0xc6, 0x7f, 0x7f, 0x7f, 0x7f, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x03, 0x01, 0x00, 0x00, 0x30
2018-11-26 18:29:59.255 Detail, Node017,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-11-26 18:29:59.255 Info, Node017, Request RTT 1585 Average Request RTT 840
2018-11-26 18:29:59.281 Detail, Node017,   Received: 0x01, 0x26, 0x00, 0x04, 0x00, 0x11, 0x1e, 0x98, 0x81, 0x8a, 0x4e, 0xb5, 0x67, 0x96, 0x6a, 0x69, 0x5a, 0x7b, 0x69, 0xe0, 0xc4, 0x6e, 0x8d, 0x91, 0xca, 0xb0, 0x1d, 0x03, 0xc8, 0x63, 0x48, 0x98, 0x26, 0x38, 0x22, 0xee, 0x40, 0xc6, 0x00, 0x1d
2018-11-26 18:29:59.282 Info, Raw: 0x98, 0x81, 0x8a, 0x4e, 0xb5, 0x67, 0x96, 0x6a, 0x69, 0x5a, 0x7b, 0x69, 0xe0, 0xc4, 0x6e, 0x8d, 0x91, 0xca, 0xb0, 0x1d, 0x03, 0xc8, 0x63, 0x48, 0x98, 0x26, 0x38, 0x22, 0xee, 0x40, 0xc6
2018-11-26 18:29:59.282 Detail, Node017, Decrypted Packet: 0x00, 0x32, 0x02, 0x21, 0x32, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00
2018-11-26 18:29:59.282 Info, Node017, Response RTT 1611 Average Response RTT 955
2018-11-26 18:29:59.282 Detail, Node017, Refreshed Value: old value=false, new value=false, type=bool
2018-11-26 18:29:59.282 Detail, Node017, Changes to this value are not verified
2018-11-26 18:29:59.282 Info, Node017, Received Meter report from node 17: Power=0.0W
2018-11-26 18:29:59.282 Detail, Node017, Refreshed Value: old value=0.0, new value=0.0, type=decimal
2018-11-26 18:29:59.282 Detail, Node017, Notification: ValueChanged
2018-11-26 18:29:59.291 Detail, Node017, Notification: ValueChanged
2018-11-26 18:30:07.671 Error, Node017, ERROR: Dropping command, expected response not received after 1 attempt(s)
2018-11-26 18:30:07.671 Detail, Node017, Removing current message
2018-11-26 18:30:07.671 Detail, Node017, Notification: Notification - TimeOut
This device is not yet fully supported by OpenZWave (and therefore HA). Someone is trying to add it though.
It could be that a part of the config file is necessary to get the status updates. It’s definitely true that you need the config file to set the config parameters in the Z-Wave control panel.
