So I have a bunch of Fibaro Wall Plug (FGWP102 with firmware 3.2, using Z-Wave JS UI). A few of them seem to report power usage very frequent, like multiple per second sometimes. It is way to frequent. And it is this due to for some reason jumping between 0W and 0.3W and then back to 0W, and it just continues. Now, there is ONE thing here: The ones with this behavior actually are just used to reporting power usage (like dishwasher, fridge and washing machine) and I have set them to be ON at all times. I just can not see if that is the cause of this. Anyway, this is from the log from just one such incident:
2025-12-22 17:25:06.006 SERIAL « 0x011800a800000100280a560131050422000349b800ab007f7f70 (26 bytes)
2025-12-22 17:25:06.007 SERIAL » [ACK] (0x06)
2025-12-22 17:25:06.008 CNTRLR [Node 040] [Multilevel Sensor] Power: metadata updated [Endpoint 0]
2025-12-22 17:25:06.008 INFO Z-WAVE: [Node 040] Metadata updated: 49-0-Power
2025-12-22 17:25:06.008 CNTRLR [Node 040] [~] [Multilevel Sensor] Power: 0 => 0.3 [Endpoint 0]
2025-12-22 17:25:06.009 INFO Z-WAVE: [Node 040] Value updated: 49-0-Power 0 => 0.3
2025-12-22 17:25:06.009 DRIVER « [Node 040] [REQ] [BridgeApplicationCommand]
│ RSSI: -85 dBm
└─[CRC16CCCommandEncapsulation]
└─[MultilevelSensorCCReport]
sensor type: Power
scale: Watt
value: 0.3
So the question then: Is there any way I can change any parameter inside the Fibaro Wall Plug FGWP102, so that for example power under 1W is NOT reporter or something? Any ideas?
