Fibaro Wall Plug shutting off although it shouldn't
I have since a couple of weeks a Fibaro Wall Plug which is configured as “Always On”.
I am using it to meassure the power of the washing maschine to know when it is finished.
Since today I have the issue, that it is shutting off after a couple of minutes after the Washing Maschine started.
Here is the ZWave Log: The Wall Plug is Node0004
2018-06-08 08:12:15.192 Info, Node004, Received SensorMultiLevel report from node 4, instance 1, Power: value=1992.5W
2018-06-08 08:12:15.192 Detail, Node004, Refreshed Value: old value=1521.8, new value=1992.5, type=decimal
2018-06-08 08:12:15.192 Detail, Node004, Changes to this value are not verified
2018-06-08 08:12:15.193 Detail, Node004, Notification: ValueChanged
2018-06-08 08:12:41.191 Detail, Node004,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x04, 0x06, 0x31, 0x05, 0x04, 0x22, 0x75, 0x30, 0xa2
2018-06-08 08:12:41.191 Info, Node004, Received SensorMultiLevel report from node 4, instance 1, Power: value=3000.0W
2018-06-08 08:12:41.192 Detail, Node004, Refreshed Value: old value=1992.5, new value=3000.0, type=decimal
2018-06-08 08:12:41.192 Detail, Node004, Changes to this value are not verified
2018-06-08 08:12:41.192 Detail, Node004, Notification: ValueChanged
2018-06-08 08:12:42.191 Detail, Node004,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x04, 0x06, 0x31, 0x05, 0x04, 0x22, 0x55, 0x18, 0xaa
2018-06-08 08:12:42.191 Info, Node004, Received SensorMultiLevel report from node 4, instance 1, Power: value=2178.4W
2018-06-08 08:12:42.192 Detail, Node004, Refreshed Value: old value=3000.0, new value=2178.4, type=decimal
2018-06-08 08:12:42.192 Detail, Node004, Changes to this value are not verified
2018-06-08 08:12:42.192 Detail, Node004, Notification: ValueChanged
2018-06-08 08:13:02.108 Detail, Node004,   Received: 0x01, 0x0f, 0x00, 0x04, 0x00, 0x04, 0x09, 0x71, 0x05, 0x00, 0x00, 0x00, 0xff, 0x08, 0x06, 0x00, 0x7c
2018-06-08 08:13:02.109 Info, Node004, Received Alarm report: type=0, level=0
2018-06-08 08:13:02.109 Detail, Node004, Refreshed Value: old value=0, new value=0, type=byte
2018-06-08 08:13:02.110 Detail, Node004, Changes to this value are not verified
2018-06-08 08:13:02.110 Detail, Node004, Refreshed Value: old value=0, new value=0, type=byte
2018-06-08 08:13:02.111 Detail, Node004, Notification: ValueChanged
2018-06-08 08:13:02.115 Detail, Node004, Notification: ValueChanged
2018-06-08 08:13:02.134 Detail, Node004,   Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x04, 0x02, 0x98, 0x40, 0x2d
2018-06-08 08:13:02.135 Info, Node004, Received SecurityCmd_NonceGet from node 4
2018-06-08 08:13:02.136 Info, NONCES: 0x4a, 0x6a, 0x45, 0xb8, 0x7c, 0x0f, 0x5b, 0x7a
2018-06-08 08:13:02.136 Info, NONCES: 0xe1, 0xe2, 0x2b, 0x67, 0x7c, 0x4c, 0x96, 0x67
2018-06-08 08:13:02.136 Info, NONCES: 0x11, 0x05, 0x75, 0x10, 0x3c, 0xf8, 0xe6, 0xd9
2018-06-08 08:13:02.136 Info, NONCES: 0x18, 0x22, 0x85, 0x14, 0x11, 0x34, 0x76, 0xd1
2018-06-08 08:13:02.137 Info, NONCES: 0xc8, 0xaa, 0xd8, 0x66, 0x45, 0x48, 0x43, 0xf5
2018-06-08 08:13:02.137 Info, NONCES: 0x52, 0x4c, 0x87, 0xbe, 0x78, 0x92, 0xdf, 0xcd
2018-06-08 08:13:02.138 Info, NONCES: 0x43, 0x28, 0xce, 0xe2, 0x3a, 0x82, 0xf3, 0xb9
2018-06-08 08:13:02.138 Info, NONCES: 0x5b, 0x5a, 0x6f, 0x4e, 0x66, 0x4a, 0xe3, 0xa5
2018-06-08 08:13:02.138 Info, Node004, Sending (WakeUp) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x04, 0x0a, 0x98, 0x80, 0xe1, 0xe2, 0x2b, 0x67, 0x7c, 0x4c, 0x96, 0x67, 0x05, 0x01, 0x61:
2018-06-08 08:13:02.144 Detail,   Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-06-08 08:13:02.145 Detail,   ZW_SEND_DATA delivered to Z-Wave stack
2018-06-08 08:13:02.165 Detail,   Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x03, 0xe9
2018-06-08 08:13:02.165 Detail,   ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2018-06-08 08:13:02.184 Detail, Node004,   Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x04, 0x17, 0x98, 0x81, 0x17, 0x8d, 0x4a, 0x69, 0x39, 0xd8, 0xe1, 0x45, 0x6b, 0xb2, 0xb7, 0x5e, 0xe1, 0xf6, 0x1f, 0x32, 0x65, 0x91, 0xde, 0x05, 0x19, 0x2c
2018-06-08 08:13:02.185 Info, Raw: 0x98, 0x81, 0x17, 0x8d, 0x4a, 0x69, 0x39, 0xd8, 0xe1, 0x45, 0x6b, 0xb2, 0xb7, 0x5e, 0xe1, 0xf6, 0x1f, 0x32, 0x65, 0x91, 0xde, 0x05, 0x19, 0x2c
2018-06-08 08:13:02.185 Detail, Node004, Decrypted Packet: 0x00, 0x25, 0x03, 0x00
2018-06-08 08:13:02.185 Info, Node004, Received SwitchBinary report from node 4: level=Off
2018-06-08 08:13:02.185 Detail, Node004, Refreshed Value: old value=true, new value=false, type=bool
2018-06-08 08:13:02.185 Detail, Node004, Changes to this value are not verified
2018-06-08 08:13:02.186 Detail, Node004, Notification: ValueChanged
2018-06-08 08:13:02.907 Detail, Node004,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x04, 0x06, 0x31, 0x05, 0x04, 0x22, 0x00, 0x00, 0xe7
Overload Saftey Switch is disabled…
Br,
Johannes
