Fibaro wall plug
Hello HAS,
I would like to operate the fibaro wall plug gen5 when there is movement in the garage (sensor.aeotec_zw100_multisensor_6_burglar) so I made an automation however it is not working.
Can someone tell me what I do wrong (configuration is a Synology server HAS server with a Aeotec zwave usb controller)
- action:
  - alias: switch
  turn_on:
service: homeassistant.turn_on
entity_id: switch.fibaro_system_fgwpef_wall_plug_gen5_switch
  alias: Garageverlichting aan
  - entity_id: sensor.aeotec_zw100_multisensor_6_burglar
platform: state
to: '8'
The above should look like this…
 - id: '72057594160168960'
     - platform: state
       to: '8'
     - service: homeassistant.turn_on
Hope that helps :slight_smile:
It works, thank you so much, I even extent it with the functionality that the light switch off after a certain time.
I appreciate your help.
    platform: state
    to: '8'
  alias: Garageverlichting uit
    platform: state
    to: '0'
    for:
      minutes: 1
    service: homeassistant.turn_off
No problem, glad I was able to help :slight_smile:
