Fibaro zwave dimmer state not changed by homeassistant
This morning after upgrading all the packets on the Raspberry Pi (Raspbian) I use to run Home assistant (python virtual env), I had to restart the Raspberry Pi.
After restart, homeassistant works fine except one module : zwave.
I have a Fibaro Z-Wave Dmmer 2 connected to an Aeon stick.
I can see the entity but acting on the dimmer state in the HA UI does not change the light and changing the light does not change the UI.
I have uploaded to pastebin the latest lines of the Zwave logs from the config tag after trying to turn the light off : https://pastebin.com/cV99GtVD
Does anyone has an idea ?
Thanks.
Okay, it seems that I have the dimmer registered twice in the zwave component (or maybe in the stick or openzwave I’m not sure).
When I go to the Services tab and select light.turn_on, the drop-down menu for entity shows me two options :
  • light.fibaro_system_fgd212_dimmer_2_level
  • light.fibaro_system_fgd212_dimmer_2_level_2
If I use light.fibaro_system_fgd212_dimmer_2_level_2 it works and I can toggle and dim the light.
I will fix mw groups and HA config to use this now.
Is there a reason and a way to fix this as I only own one zwave dimmer (and actually only one ZWave device apart from the Aeon USB stick) ?
Hello, I am trying to control my lights with FGD212 from the HA frontend. Do you manage to get this work ?
I am new to Home Assistant and I managed to integrate my Netatmo meteo station and thermostat, also my IP camera and my Broadlink plug. But I am struggling to figure out the right configuration.yaml to enable switching on/off the lights from the HA frontend.
Can you share your configuration.yaml ?
Thank-you :slight_smile:
I have got the same. I Could not remember that i have included the device twice. I have somehow also a light.level and I can use that to control it. Did you manage to solve it?
I found how to achieve what I wanted :
I added in configuration.yaml
  lights:
    view: yes
    entities:
      - light.level_2 # used to pilot the lights via FGD212 (found via light.turn_on service panel)
And in customize.yaml
# Fibaro FGD-212
light.level_2:
  friendly_name: Veranda Lights
I have got the same code. But it seems to be wrong to me that every Fibaro dimmer is called light.level
I renamed mine and when I select it, il show the name I have set. So it is simple to know what dimmer is where (level_x) … I use customize.yaml to have an understandable name.
Hello all
a also recently added the Fibaro dimmer and it automatically added two switches
and
while only the second one actually switches the light
no clue why it is added twice.
cheers, alphalz
