“If you discover that you need to invert the operation of open/close for a particular device, you may change this behavior in your Z-Wave section of your configuration.yaml”
But the problem still there evenif I modified the code.
It’s really strange because as I mentionned in my first reply. It’s only a problem with the feedback in history graph and the Up arrow is in grey color and I can’t use it evenif the roller blind is closed …
Up and Down arrows works fine when the cover is not entierly open or close. So I think that it’s not a probleme with inverted commands.
Does your roller blind have limit switches for top and bottom limit ?
If you wind your blind all the way down, then up greys out, it sounds as though your limit switches have been mixed up. ie: top switch wired into bottom limit etc.
I don’t think that the problem is the limit switches.
They are wired in the motor and the FGR 222 don’t have any connectors to connect to limit switches.
That’s strange because up and down arrows works fine with the good direction. It’s only the feedback interpretation of Hass that is wrong.
Did you find a solution to your problem ?
I was almost in the same situation, except that I had to use invert_openclose_buttons to have the arrows buttons work as expected.
But unfortunatly, the position seems to be reversed… thus when the cover is completely closed, the up button will be grey out (as the system thinks it’s completely open).
