Field not registering any value despite default
I am running into a problem with my script where for some reason my field (Wait for Test) says it is not defined. Despite having a default value. I am not sure what the problem is as other fields in other projects work as normal. Thank you for your attention
alias: Cover Time Test
sequence:
  - action: logbook.log
      message: "wait_for_test value is: {{ wait_for_test }}"
      entity_id: sensor.logger
  - action: counter.reset
    metadata: {}
    data: {}
      entity_id:
        - counter.test_helper_warnings
        - counter.test_helper_failure
        - counter.test_helper_success
  - variables:
      entities: >
        {{ states.cover | map(attribute='entity_id') | select('string') | list
      full_time: 0
  - action: counter.set_value
    metadata: {}
      value: "{{ entities | length }}"
      entity_id: counter.test_helper_total_number_of_devices
  - repeat:
      count: "{{ entities | length }}"
      sequence:
        - variables:
            current_entity_id: "{{ entities[repeat.index - 1] }}"
        - if:
            - condition: template
              value_template: |
                {{ state_attr(current_entity_id, 'current_position') != None }}
          then:
                message: >
                  Testing {{ current_entity_id }} with position: {{
                  state_attr(current_entity_id, 'current_position') }}.
          else:
                message: >
                  {{ current_entity_id }} is missing the 'current_position'
                  attribute.
            - action: counter.increment
              metadata: {}
              data: {}
                entity_id: counter.test_helper_warnings
        - target:
            entity_id: "{{ current_entity_id }}"
          action: cover.open_cover
        - delay:
            seconds: 1
  - delay:
      minutes: "{{ wait_for_test}}"
    enabled: false
    metadata: {}
      message: Finished Waiting
  - variables:
      start_time: "{{ now().timestamp() }}"
  - repeat:
      sequence:
        - variables:
          metadata: {}
            message: "Closing {{ current_entity_id }} "
        - target:
          action: cover.close_cover
        - delay:
            seconds: 1
  - repeat:
      sequence:
          metadata: {}
            message: Inside the finishing loop
        - variables:
        - variables:
            timeout_duration: >
              "00:{{ '0' if wait_for_test < 10 else '' }}{{ wait_for_test
              }}:00"
            message: "timeout_duration value is: {{ timeout_duration }}"
        - wait_template: "{{ state(current_entity_id) == 'closed' }}"
          continue_on_timeout: true
          timeout: "{{ timeout_duration }}"
            message: "state value is: {{ state(current_entity_id) }}"
        - variables:
            time_to_test: >
              {{ max(0, (states[entity_id].last_changed -
              start_time).total_seconds()) }}
          metadata: {}
            message: "Time to Test {{time_to_test}} "
        - if:
              value_template: "{{ time_to_test == 0 }}"
          then:
              metadata: {}
                message: >-
                  {{current_entity_id}} has experienced a problem with closing
                  (Maybe you didnt give it enough time?)
          else:
              metadata: {}
                message: "current entity id {{current_entity_id }} "
            - if:
                  value_template: |
                    {{ time_to_test is defined and
                       118 <= time_to_test <= 122 }}
              then:
                    message: >
                      {{ current_entity_id }} seems to have a default value of 2
                      minutes.
                  data: {}
              else:
                  metadata: {}
                    value: >-
                      {{ counter.test_helper_code_counter + (time_to_test | int)
                    entity_id: counter.test_helper_code_counter
  - repeat:
      sequence:
          metadata: {}
            message: "Testing the times to see an outlier "
        - variables:
        - if:
              value_template: |
                   ((states('counter.test_helper_code_counter') | int) / entities | length) -
                   acceptable_margin <= time_to_test <=
                   ((states('counter.test_helper_code_counter') | int) / entities | length) +
                   acceptable_margin }}
          then:
                message: >
                  {{ current_entity_id }} has a normal test time of {{
                  time_to_test }} seconds.
          else:
                message: >
                  {{ current_entity_id }} has an abnormal test time of {{
              data: {}
description: >-
  Tests if the time for a cover to open/close is within an acceptable range,
  logs warnings for missing attributes or abnormal values.
fields:
  acceptable_margin:
    selector:
      number:
        min: 1
        max: 120
    description: How many seconds can the value deviate from the average
    default: 30
    required: true
  wait_for_test:
    selector:
      number:
        min: 1
        max: 30
    name: Wait for Test
    description: >-
      How many minutes do you want bettewen steps of testing (should be the
      value of the largest blind closing time)
    default: 5
    required: true
Hello Rodrigo_Baiao,
This is where the actual error message would be Sooo helpful…
My guess it it’s happening in the 4th repeat (repeat[3]) because in there you are using the variables pulled from the fields out of scope. They are in an inner repeat loop and have no value there.
That’s my guess anyway…
Sorry, I didnt include the error message because it was simply that I couldnt execute the script due to Unknown Error. I do know it is for the Wait for Test Variable if that helps, I realized I forgot to include that in the original message
OK, but you might have missed the point. It’s a scope problem. The variable in the inner repeat is different scope than the one in the field, so they are not the same.
You may have to use namespace, or create a helper or another way to create a global in order to refer to that in the inner repeat loop.
Trigger based template sensor to store global variables.
You defined it in the fields, but that doesn’t mean it’s supplied when you don’t populate the variable.
The default here
is only for the UI, it does not actually populate wait_for_test with a value. If you want to do that, you need to use wait_for_test | default(5) in your template code
I was not aware of that, I thought default would set it as a default value and not just an UI thing. Thank you for the help
