Why do we get two levels? The second button or scene is activated without one as it seems
The device database entry is usually based either on the user manual or other manufacturer supplied documentation. This question appears to be better directed at the vendor support department.
With not so many dimmers around i would guess that at least 20% of the community here uses them. Several topics i’ve found addressed that the level2 was for the second button. But seems it works even disabling.
If you wire the second button up to it then you can adjust it with the button. However, you can also use the scene events to get button presses. I have found it is just simpler to use the second level in some cases than to deal with scenes. (I really just see it as added flexibility.)
Thats the point. I dont get it. Scene functionality now gets called directly on the node and it works with level2 disabled
- platform: event
event_type: zwave_js_value_notification
event_data:
node_id: 3
value_raw: 26
I’m afraid don’t quite follow.
If I understand you correctly, you have a physical switch hooked up to the second switch input and you get a scene event when it is physically activated? But you have it disabled. What do you mean by disabled?
As you can see in the example above the event is called with a node_id and raw event value.
Fibaro dimmer creates 2 entities in the HA.
fibaro_dimmer_level
and
fibaro_dummer_level2
So the second entity is disabled via the integrations page in HA.
I’m still confused as to what you are trying to achieve. If I press on switch 1 I get one scene and if I press on switch 2 I get another scene. When I do switch 1, then dimmer 1 changes, and when I do switch 2, dimmer 2 changes. (Dimmer 2 isn’t a real dimmer since the physical device only has one dimmer, though.)
The values are the same as in the instruction manual.
Here is the scene I get when I press on switch 2 (and it changes the second switch if it is a single press):
"event_type": "zwave_js_value_notification",
"data": {
"domain": "zwave_js",
"node_id": 43,
"home_id": 4110823651,
"endpoint": 0,
"device_id": "94d636c8a8cf5b52227c5dbd6d93f048",
"command_class": 43,
"command_class_name": "Scene Activation",
"label": "Scene ID",
"property": "sceneId",
"property_name": "sceneId",
"property_key": null,
"property_key_name": null,
"value": 26,
"value_raw": 26
"origin": "LOCAL",
"time_fired": "2022-01-16T16:26:24.076722+00:00",
"context": {
"id": "fb3c406c58aab6c702d71d0fde5dbcb4",
"parent_id": null,
"user_id": null
And here is what I get when I press on switch 1 (and it changes switch 1 if it is a single press):
"data": {
"node_id": 43,
"endpoint": 0,
"value": 16,
"value_raw": 16
"origin": "LOCAL",
"time_fired": "2022-01-16T16:26:21.560285+00:00",
"context": {
"id": "8a485961acfcac912ba5958011c0e237",
"parent_id": null,
"user_id": null
This is what I would expect from the setup.
Is there something different you were expecting, or (more likely) I’m not understanding what you are trying to do.
-David
