There is a new tool coming out of the Docker container space called ORAS cli https://oras.land/ that allows you to treat files or “artifacts” as a docker container, meaning you can store anything in a container registry. There is no docker engine requirement.
As an example, I have a firmware file for my iot product, which i store in the home assistant registry that allows for OTA updates. Users of home assistant do not need to search for firmware updates.
If this can move forward as a standard, especially with Matter coming out,
- devices can have a live/ mirrored/ airgapped registry available with home assistant that allows for holding any files needed.
- this type of management would also lend itself as a one stop shop for developers of any platform
- firmware artifacts are now centrally version controlled so you can easily rollback
- a central standard for holding any type of file for the entire ecosystem.
