File Editor add-on "broken" since clearing cache
Hi, I am on HA 0.118.3. But i thnk I av thi s problem since late 0.117 or early 0.118.
The thing is on any browsr that I cleared cache my FIle editor in not showing File editor.
Insted of that it is showing me somthing else. The ones I didn clear cahahe I can acess File Editor normally.
I tried reinstalling the addon, but is the same issue.
The browser is unable to load external resources. Some components are fetched from CDN’s, and some browser-addons or privacy-tools block access to those. So if you have something like pihole or some sort of Java Script blocker enabled, the browser can’t access those dependencies.
You are completely right my AdGuard Home was blocking it.
Thank you.
So, what did you do to fix the issue?
