Hi, I have installed hassio on a rasperry pi 4. I get the following error when trying to install File editor addon:
Failed to install add-on
Can’t install homeassistant/armv7-addon-configurator:5.3.3: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=5.3.3&fromImage=homeassistant%2Farmv7-addon-configurator: Internal Server Error (“Get “https://registry-1.docker.io/v2/”: x509: certificate has expired or is not yet valid: current time 2021-10-18T18:05:36Z is before 2021-11-30T00:00:00Z”)
I am new with HA, Could you help me to find where is the problem? thank you
