I see great potential with the file integration in Home Assistant, but I can’t get it to work. I’ve tried numerous combinations and eventually went back to trying to make it work by entering the information directly from the page describing the integration: File - Home Assistant. But even that doesn’t work; I can’t figure out what I’m doing wrong. I get a warning in the log: “File or data not present at the moment: sensor.json”
It must have something to do with the path?
Here’s how my settings look now:
And in the File Integration UI:
The JSON file config/sensor.json:
Any ideas?
