Hello!
i have a txt file, reading the values with file sensor works good
unfortunately i would need the value as number instead of list for further processing:
this is the textfile format:
2,8;22,4;20,8;5,4;0,1;0,4
these are temperatures.
i read the values with a sensor like this in my configuration yaml:
- platform: file
name: Wswin Aussentemperatur
file_path: /config/www/wswin/hass.txt
value_template: >
{{ (value.split(';')[0])}}
unit_of_measurement: '°C'
the output of the sensor.wswin_aussentemperatur is 2,8 in this case but to use it e.g. in a canvas gauge card, the output must be 2.8 (point instead of a comma). how can i change this? It is not possible to change the the format of the inputfile “hass.txt”
thank you!
regards, Gerwin.
