File sensor directory hassio help
hi
i’m trying to set up the file sensor without success
- platform: file
  file_path: /share/todays_events.txt
no matter what folder i choose i get the following error
Failed config
  sensor.file:
    - Invalid config for [sensor.file]: not a file for dictionary value @ data['file_path']. Got '/share/todays_events.txt'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.file/
    - platform: file
Successful config (partial)
  sensor.file:
can someone please help
Did you “Note that file paths must be added to whitelist_external_dirs.”
I started again
so I have this in my config
   whitelist_external_dirs:
     - /config/test
and this is the sensor
- platform: file
  file_path: /config/test/todays_events.txt
yes I still get the error
- Invalid config for [sensor.file]: not a file for dictionary value @ data['file_path']. Got '/config/test/todays_events.txt'. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.file/
- platform: file
Have you created /config/test and is a file in that dir called todays_events.txt
Removing the first / resolved my issue
Thank you for the support
having the same problem, but using as file_path /local/file.txt
which first / are you referring too?
First slash in you sensor setting
Here is the white list in my config
- /config/sensor_scripts
Here is my sensor
  • platform: file
    file_path: sensor_scripts/todays_events.txt
that’s my configuration
  - platform: file
    file_path: local/filed_automations.txt
    name: Filed automations
homeassistant:
     - /config/www
     - /config/python_scripts
still error. I am on HASSIO
2018-12-08 11:50:03 ERROR (MainThread) [homeassistant.config] Invalid config for [sensor.file]: not a file for dictionary value @ data[‘file_path’]. Got ‘local/filed_automations.txt’. (See ?, line ?). Please check the docs
Your using a path in your sensor that’s not the same as what you have white listed.
I’m sure you don’t need to white list www
I added whitelist because had the error (and still have)
Try placing your txt file in your python_scripts folder and change the sensor to python_scripts/filed_automation.txt and see if it works
I know this is an old thread. Thank you for the help on the directory part. Also My Acurite station output a csv and I figured out that it is case sensitive. in my case it must be “.CSV” not “.csv”. Maybe that will help someone in the future.
Overall this thread helped alot, but there is no single example of a working config, and I feel that it would be helpful for future visitors:
For me, I created a file, that contains either 1 or 0, it is updated by a cron job on the OS, and my supervised Home Assistant install monitors it.
The OS path for the file is:
/usr/share/hassio/homeassistant/_my/data/flag_file
The same path from within the Home Assistant container is:
/config/_my/data/flag_file
In my /config/configuration.yaml I have the following under homeassistant:
homeassistant:
  allowlist_external_dirs:
    - "/config/_my/data"
  packages: !include_dir_named _my/packages
This loads pacakge files from /config/_my/packages' and whitelists _my/datapath under/config`
My file sensor configuration is placed in /config/_my/packages/flag_file.yaml:
- platform: file
  file_path: "config/_my/data/flag-file"
After restarting, I now have an entity named sensor.flag_file with the content of the file.
