Hello all,
I think I’m missing something obvious here but whatever I do I cannot get a file sensor to appear in the entity states page, can any one spot what I am doing wrong?
Here is my config Hassio (69.1):
created sensor.json text file inside config i.e. where configuration.yaml resides
pasted in following text lines into sensor.json and saved, for purposes of testing:
{“temperature”: 21, “humidity”: 39}
{“temperature”: 22, “humidity”: 36}
- sensors.yaml ( all other sensors are working inside this include file )
- platform: file
file_path: sensor.json
value_template: '{{ value_json.temperature }}'
unit_of_measurement: '°C'
- configuration.yaml (under section homeassistant: )
whitelist_external_dirs:
- config
When I check configuration via
hassio ha check
I get the following error:
KeyError: ‘packages’
Fatal error while loading config: ‘packages’
Failed config
General Errors:
- ‘packages’
Successful config (partial)
If I have whitelisted folders active
If I remove the whitelist_external_dirs I don’t get any errors but sensor.filetemp never ever appears either way, I’m not sure I need to use whitelist_external_dirs since my text file is in the config folder?
It seems like it should be straightforward but I’m completely stumped with getting this to work??
