Hello ,
To monitor the size of the HA DB size , a sensor has been created as per the filesize documentation … File Size - Home Assistant
- platform: filesize
file_paths:
- /config/home-assistant_V2.db
- /config/home-assistant.log
There is a configuration problem when the file extension is “.db” only ,but it is successul if the file extension “.log” for example.
The screenshot of the error
Is it a known issue or just me ?
Thank you to confirm
