I have a sensor created like this:
mqtt:
- name: "BoilerTemp"
state_topic: "BSB/json"
unit_of_measurement: "..C"
value_template: "{{ value_json.BSB.value }}"
And this is the json where that’s get send to the Mosquito broker:
"BSB": {
"id": 8830,
"name": "DHW temperature actual value top (B3)",
"value": "43.8",
"desc": "",
"unit": "°C",
"error": 0
This all works fine if I just get 1 message. If I add extra messages to be sent by the mqtt client it starts to get challenging. They all end up in the same topic BSB/json and also have the same format:
Like this:
"BSB": {
"id": 8830,
"value": "43.8",
"desc": "",
"unit": "°C",
"error": 0
"BSB": {
"id": 8700,
"name": "Outside temp sensor local",
"value": "27.0",
"desc": "",
"unit": "°C",
"error": 0
I want to create a sensor per “id”
So I need to find a way to tell the sensor to only accept data if “id”==“8700” for a certain sensor and if “id”==“xxxx” for any other example.
I do know the logic but I cant find a example to get this done in the sensor config.
Any help or example would be much appreciated. Let me know if there is a better approach in HA
