I’m trying to get a more accurate range of values from a DIY bed presence sensor to use in HA by getting a min and max value over the past 5 values. If any value min is below x or above y I can the safely determine the bed is occupied or not.
However, the min/max sensors are really slow to change and respond. It takes about 5 minutes for a change to process, while the window is set to only 5, so I basically assumed this would take 5 seconds at most?
This is my current config:
esp32_touch:
setup_mode: false
binary_sensor:
- platform: esp32_touch
pin: GPIO15
threshold: 48
filters:
- delayed_on_off: 1s
name: "Bed Top Right Readings"
update_interval: 5s
accuracy_decimals: 0
lambda: |-
return ((uint32_t) id(top_right)->get_value());
filters:
- min:
window_size: 5
send_every: 5
send_first_at: 5
lambda: |-
filters:
- max:
window_size: 5
send_every: 5
send_first_at: 5
lambda: |-
Any ideas what I’m doing wrong or is this supposed to take this long?
Regards,
Eduard
