Just added Home Assistant the mix of a Wink2 hub, Ecobee thermostats, and assorted lights. Previously the Ecobee was added to the Wink hub so I could manage it from a single interface.
With the HA install I added the Wink and it was good, but the Ecobee sensors didn’t show up. So I enabled Ecobee login from HA and everything else was exposed. Now I have a 2nd copy of entities associated with the Ecobee. For example, I have sensor.office_temperature and sensor.office_temperature_2. I can add the first copy to a group, however _2 is left up in the top as a sensor.
Is there anyway to filter out the extra entities in the web interface, or should I just remove Ecobee from the Wink configuration?
Cheers,
Bob
