This Philips hue dimmer sends multiple payloads when a button is pressed.
For example:
Pressing the ON button (on_press) sends the following:
Holding the ON button (on_hold) sends the following:
The problems comes in when I want to distinguish on_press from on_hold.
Holding the on button (on_hold) also always sends on_press message.
If I use a switch node, when I on_hold, it also sends on_press.
Is there some way of collecting all of the sent messages and only sending them based on some hierarchy. For example.
If array contains [on_hold, on_press, on_hold_release] only send on_hold and ignore the rest.
I would prefer to not have to use a function node if possible. Is there an existing node that can do this?
