Hello everybody,
I am new to HA . Things I want to learn from this topic:
- How to debug a similar Problem next time
- How to create a moving average filter for an existing sensor
Problem: I want to switch a dehumidifier on if my average solar power is above 300W during the last hour and switch it of it was below 100W. For that I need to calculate the average solar power.
My Idea was to copy the code block from Filter - Home Assistant
# Example configuration.yaml entry
- platform: filter
name: "filtered realistic humidity"
entity_id: sensor.realistic_humidity
filters:
- filter: outlier
window_size: 4
radius: 4.0
- filter: lowpass
time_constant: 10
precision: 2
- platform: filter
name: "filtered realistic temperature"
entity_id: sensor.realistic_temperature
filters:
- filter: outlier
window_size: 4
radius: 2.0
- filter: lowpass
time_constant: 10
- filter: time_simple_moving_average
window_size: "00:05"
precision: 2
the resulting configuration.yaml looks like this: (bottem section should be interesting)
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
script: !include scripts.yaml
scene: !include scenes.yaml
input_number:
box1:
initial: 2000
min: 0
max: 3600
step: 1
mode: box
box2:
initial: -50
min: -600
max: 5000
step: 1
mode: box
template:
- sensor:
- name: "Heizer_Prozent"
unit_of_measurement: "%"
state: >
{% if is_state('fan.heizer_pwm_fan', 'on') %}
{{ state_attr("fan.heizer_pwm_fan", "percentage") }}
{% else %}
0
{% endif %}
- name: "Heizer_Leistung"
unit_of_measurement: "W"
state: >
{{ state_attr("fan.heizer_pwm_fan", "percentage") / 100 * states('input_number.box1')|float }}
{% else %}
0
{% endif %}
- name: "Heizer_Bool"
unit_of_measurement: ""
state: >
1
{% else %}
0
{% endif %}
- name: "Rechnerische Leistung"
unique_id: 7145e5a0-caf3-4fef-b99d-d95d0cfd1b0d
state: "{{ states('sensor.leistung_phase_1')|float + states('sensor.leistung_phase_2')|float + states('sensor.leistung_phase_3')|float }}"
mqtt:
- name: "Leistung"
#state_topic: "tele/Tasmota_Stromzaehler/SENSOR"
state_topic: "stat/Tasmota_Stromzaehler/STATUS8"
suggested_display_precision: 1
#value_template: "{{ value_json.SML.curr_w }}"
value_template: "{{ value_json.StatusSNS.SML.curr_w }}"
- name: "Summe_Stromverbrauch"
suggested_display_precision: 3
unit_of_measurement: "kWh"
value_template: "{{ value_json.SML.total_kwh }}"
- name: "Summe_Einspeisung"
suggested_display_precision: 5
value_template: "{{ value_json.SML.export_total_kwh }}"
- name: "Leistung_Phase_1"
unique_id: 7145e5a0-caf3-4fef-b99d-d95d0cfd1b0a
value_template: "{{ value_json.SML.volt_p1 * value_json.SML.amp_p1 * cos(value_json.SML.phase_angle_p1 * 3.1415926 / 180) }}"
- name: "Leistung_Phase_2"
unique_id: 7145e5a0-caf3-4fef-b99d-d95d0cfd1b0b
value_template: "{{ value_json.SML.volt_p2 * value_json.SML.amp_p2 * cos(value_json.SML.phase_angle_p2 * 3.1415926 / 180) }}"
- name: "Leistung_Phase_3"
unique_id: 7145e5a0-caf3-4fef-b99d-d95d0cfd1b0c
value_template: "{{ value_json.SML.volt_p3 * value_json.SML.amp_p3 * cos(value_json.SML.phase_angle_p3 * 3.1415926 / 180) }}"
- platform: filter
entity_id: sensor.balkon_power
filters:
window_size: "00:60"
Nothing happens. I would expect to find some entity sensor.Leistung_Balkonkraftwerk_Mittel or at least anything containint “Mittel” in my entity list.
The input sensor should exist:
- do you see any error?
- which log should I look at for debugging?
- why does the syntax look different for template + mqtt than for filter? The sequence of the word “sensor” and the “platform” seems illogical to me. Is that some legacy thing?
I will check the topic and edit if the code blocks do not appear as expectet. It’s my first post.
Thank you in advance.
Daniel
