using this rather contrived template, I am searching for power sensors that should be switched off, but are not correctly so for some reason, and still using power.
this was working just fine until the moment I decided to have my zwave sensors show their self power usage, so they’re always showing 0.5/0.8 even when off. filtering these doesnt work just yet
that is, they are filtered completely, and the or states(s.entity_id) == 0.5
bit is ignored…
please have a look what I should change to also have that incorporated? And ofc if there’s an obvious improvement please don’t hold back
thanks!
template:
- sensor:
- unique_id: power_using_off_switches
Power using 'off'-switches
state: >
{%- set ns = namespace(not_off=[]) %}
{% set self_power_devices_05 =
['sensor.audio_gym_actueel', 'sensor.master_bedroom_google_actueel',
'sensor.tv_tuner_badkamer_actueel'] %}
{% set self_power_devices_08 =
['sensor.vijverpomp_links_actueel','sensor.vijverpomp_rechts_actueel'] %}
{% set ignore =
['sensor.inductieplaat_actueel','sensor.patchboard_zolder_actueel'] %}
{%- for s in expand('group.switches_sensors_actueel')
if s.entity_id not in ignore and
(s.entity_id not in self_power_devices_05 or states(s.entity_id) == 0.5)
and (s.entity_id not in self_power_devices_08 or states(s.entity_id) == 0.8)
and states(s.entity_id) not in ['0','0.0'] and
states('switch.' + s.object_id.split('_actueel')[0]) == 'off' %}
{%- set ns.not_off = ns.not_off + [s.entity_id] %}
{%- endfor %}
{{ns.not_off|count}}
attributes:
list: >
{% set ignore =
{%- set ns.not_off = ns.not_off + [s.name+ ': ' + s.state + ' watt'] %}
{%- endfor %}
{% set count_not_off = ns.not_off|count %}
{% set list = ns.not_off %}
{% if count_not_off == 0 %} All fine
{% elif count_not_off == 1 %}
{{list[0]}} is still using power!
{% elif count_not_off == 2 %}
{{list|join(' and ')}} are still using power!
{% else %}
{{list[:-1]|join(', ')}}, and {{list[-1]}} are still using power!
{% endif %}
