FINALLY: A ceiling fan solution for Home Assistant
I’ve been searching all over for advice on what to buy and how to integrate (set up) a ceiling fan solution that was fully controllable from Home Assistant, but after a long time searching - only to find half-breed semi-hacked home-made solutions, mostly adapted to the US (electricity wise and brands only sold in the US), I gave up.
Until one day, in august 2024, I stumbled upon a sales guy in a LeroyMerlin shop who knew a lot more then to just say “I’m sorry…”
He showed me a new arrival - among the zillion of other ceiling fans they had, all with proprietary remote controls using 433MHz with rotating key protocols! Useless!
But this new model, made in China (of course) offered additional remote control using a smartphone. And that’s a major step in the right direction, I thought - so I took my chances and bought one unit. It’s brand name was NERE SMART. Probably just an OEM name. It may exist under other names as well. Typically Chineese. The included user guide wasn’t all that bad either. It told me to scan a QR-Code to download an app named “LightForLife” (yes - spelled like that!). I have never heard of that app, and found very little info on Google Search. So, I didn’t have much choice but to follow the guide. During installation on my Android smartphone, I noticed that the Tuya logo briefly flashed across my screen. Now that’s a familiar name, I thought, and I terminated the installation and began searching for “Smart Tuya” to see what possible link there could be. And just as I suspected, this so called “LightForLife” app was just a lobotomized subset of the full Tuya app. I wasn’t able to find anything suggesting that perhaps I could use the Tuya app instead of the “LightForLife” app, and thus be able to integrate the ceiling fan into Home Assistant using the Tuya Integration (or Local-Tuya).
So, I gave it a shot and guess what!? The Tuya app immediately recognized my Ceiling fan after putting in pairing mode!
Long story short - I decided to use the standard cloud based version of the Tuya Integration, and everything showed up in Home Assistant, with all the whistle and bells (lots of entities) for fan and light control.
So now, I’m a happy camper after all.
Hi @Viking
Have you got a link for this product?
https://www.leroymerlin.es/productos/iluminacion/ventiladores-de-techo/todos-los-ventiladores-de-techo/ventilador-de-techo-con-luz-motor-dc-nere-blanco-90078305.html?srsltid=AfmBOoood4SjSVzAqzBno3_s1K7WGvdX38PdtVTdgkRb_PDyJ9xYslW4
I clicked on that link and was sent to a landing page that said “You have been blocked.” Nothing else beside the company logo at the top.
That’s strange. Perhaps it’s because LeroyMerling is very picky about keeping strict country limits. You see, this is from LeroyMerling in Spain. Their offerings may differ from what they have in other regions. Anyway, this is what I get from this link:
SKYFAN DC works direct to HA out of the box you just buy a $25 wifi adaptor and then it works via ESPHome no cloud needed
I purchased an italian brand called “Lucci”. It uses an RF remote with no security so I was easily able to teach my broadlink RM Pro how to talk to the fan. Cost me about AUD150 from memory. Remote Model is SF-14-T3. 6 speed reversing with a cobb light in the middle. The light is 15w so we never turn it on. Its bright enough for tanning.
Please post a link to that WiFi adapter.
Mentioned here, which links off to the developer’s YouTube and website.
I ended up getting a Hunter ceiling fan with light kit along with a pair of Leviton decora switches to control lights and fan speed. I haven’t added them to HA yet, but I have the instructions and will add them in a bit.
Could you help share the model numbers or links for those?
And I’m curious - how exactly do you plan to add them to HA?
Do you mind posting the list of entities? I have the same fan that uses RF remote but no app. I want to use my broadlink to add it to HA. I want to make sure i get all the entites.
The ceiling fan is nothing special as the it is the wall switches that will be connected to HA .
The fan
Hunter Oakhurst 52 in. LED Indoor Low Profile New Bronze Ceiling Fan with Light Kit from The Home
Depot.
The switches are Leviton
ZW6HD for light dimmer switch
ZW4SF fan switch with 4 speeds
That the contractor bought for me. He did the
install and testing for me.
The switches are not connected to HA yet. I discovered that they are ZWave switches so I ordered a Zooz 800 Series USB stick that was recommended on HA subreddit. Amazon US link Zooz 800 Series Z-Wave Long Range S2 USB Stick ZST39 LR, Great for DIY Smart Home (Use with Home Assistant or HomeSeer Software) - Amazon.com
I should get it tomorrow , and I can update this thread with the results. They also make an rpi gpio card ,
but I already have a POE Hat+ installed, so the gpio connection is taken.
Update - The zwave switches are not being cooperative. I got the one for the lights detected and working after I bought a Zooz z-wave 800 usb stick, but the fan switch still won’t detect.
Get wifi switches if you can .
I have some Hampton Bay Zigbee ones that worked great with SmartThings but they only work a few days with Home Assistant. I am using Zigbee2MQTT and it still has issues. None of my other Zigbee devices do and I contacted the manufacturer and they had no clue. I would be willing to replace it with something else if I had to.
I need just a box with power in, and fan and lights out, and then some controllers for the wall (Hampton Bay’s were really just remote controls) and I do also like having a remote.
Thank you very much for this contribution. It is just what I needed. A fan with a remote and an app to connect to HA and easy to find in Spain.
Hey mate I’ve got the same remote and broadlink RM – did you use yours to control the light on that ceiling fan? I’ve done the learn command for the light button but running it just switches the light from bright to dim, not on/off. That familiar to you at all?
Ok scratch that, the issue was likely double-press during the learn command. Working fine now.
THANK YOU for this post. I’ve been looking for a decent, HA-compatible fan and it hasn’t been easy at all. It’s crazy how badly manufacturers document their systems.
You talk about the “standard cloud based version of the Tuya Integration”. Does it also work with local integration?
The problem with this is that you are limited to the single design and you cannot choose the look and feel of your ceiling fan, which is a pretty prominent feature in your room …
Instead, I use smart wall switches and they have been working beautifully with the various ceiling fans I have … not to mention, it is a much cheaper solution.
The ones I use are the combo dimmer / fan switch by Kasa. Integrated in HA through the HomeKit integration. Works beatifully
In the US Altitude sells a Matter compatible ceiling fan. Altitude Boca Raton II Limited option, but they have more on the way soon from what I have heard.
https://www.lowes.com/pd/ALTITUDE-52-IN-ALTITUDE-BOCA-II-BLK-CFAN/5015568031
