If you have an Android device available, you can get the voice by using notifications and notification reader. I use push bullet for notifications and out loud for reading those notifications.
Any news for Hassio users?
This would be a awesome addon for announcements! I want Morgan Freeman to welcome me home when i open the door lol
Could this be accomplished using a speaker connected from a Aux cable plugged in directly to the pi?
Yes. You can use the mopidy plugin for hassio for that
Thank You so much!!! I can’t wait to try it!
Can anybody give me a idea of how to install mopidy on Hassio? Im a total noob and cant find information on it.
Hi new to this myself Corey but hopefully I can help. Click on Hass.io tab & select Add on store & click on add new repository and add this link
https://github.com/bestlibre/hassio-addons & you will see the new add on’s on the list.
Thanks so much I couldn’t figure out how to get the add-on store into my UI
So I managed to get it loaded but can’t get it to run.
I added this json file
“name”: “Mopidy”,
“version”: “0.2.3”,
“slug”: “mopidy”,
“description”: “mopidy music server”,
“url”: “https://github.com/bestlibre/hassio-addons/tree/master/mopidy”,
“startup”: “application”,
“boot”: “auto”,
“image”: “bestlibre/{arch}-mopidy”,
“options”: {“local_scan”: true,
“options”: []},
“schema”: {
“local_scan”: “bool?”,
“options”: [{“name”: “str”, “value”: “str”}]
“devices”: ["/dev/snd:/dev/snd:rwm"],
“ports”: {“6680/tcp”: 6680, “6600/tcp”: 6600},
“map”: [“share”],
“webui”: “http://[HOST]:[PORT:6680]”,
“host_ipc”: true
But when I hit save the run it switches back to the original json. I’m not sure why.
I figured it out, I used this instead
“local_scan”: true,
“options”: [
“name”: “local/media_dir”,
“value”: “/share/mopidy/media”
“name”: “m3u/playlists_dir”,
“value”: “/share/mopidy/playlists/”
“name”: “gmusic/username”,
“value”: “MYUSER”
“name”: “gmusic/password”,
“value”: “MYPASSWORD”
Thanks so much buddy! Now it just figuring out how to configure it!
Hello have you figure out to make it work ? if yes can you give us some advices ?
no unfortunately not, I did get the mopidy add-on to load. And I can get sounds to play to my speaker that is connected to my pi via AUX. But that’s about it. I cant figure out how to automate sounds when devices trigger. I’ll be sure to let you know if/when I figure it out!
Another one trying to connect a Bluetooth speaker!
Another person who would love to be able to connect a bluetooth speaker to HA so I can use it for TTY and Spotify. Going to try to go the aux route, but that’s far less favorable.
Apologies for the necropost, but I’m still looking for how to use a bluetooth speaker as an external speaker/microphone, too…
It looks like there may be a chance of some development over here.
