HI,
This code is giving errors in the data fields, can you spot what im doing wrong? Thanks for checking:
automation:
- alias: Dining Table Scene
platform: state
entity_id: input_select.select_hue_scene_dining_table
- service: hue.hue_activate_scene
data_template:
group_name: dining_table
scene_name: '{{ states.input_select.select_hue_scene_dining_table.state}}'
input_select:
select_hue_scene_dining_table:
name: Hue Scene Dining table
icon: mdi:palette
options:
- Arctic Aurora
- Bright
- Concentrate
- Cool White
- Dimmed
- Energize
- Nightlight
- Read
- Relax
- Savanna Sunset
- Spring Blossom
- Tropical Twilight
initial: 'Relax'
I do something almost identical to this…
link removed
Input _select is at the top, automation and script near the bottom. And then the script can also be called from elsewhere.
Note that the scene name in the input_select has to match the scene name on the hub exactly (including case).
Hope this helps.
NIce!
Always tricky to find the optimal solution between automations scripts and scenes … I like the script setting the scene and group from init_selects, exactly what i was looking for.
Cheers,
Marius
so , just to economize, (ill leave the hand made scenes for later, and only use the Hue scenes)
ill only need this?:
input_select:
dining_table_scenes:
options:
- Select
- Arctic aurora
- Bright
- Concentrate
- Dimmed
- Energize
- Nightlight
- Read
- Relax
- Savanna sunset
- Spring blossom
- Tropical twilight
initial: Select
icon: mdi:creation
automation:
- alias: Reset scene selector - Dining-table
initial_state: 'on'
platform: state
entity_id: light.dining_table
to: 'off'
condition:
condition: template
value_template: "{{ not is_state('input_select.dining_table_scenes' ,'Select') }}"
service: input_select.select_option
entity_id: input_select.dining_table_scenes
option: Select
- alias: Trigger scene - Dining table
initial_state: 'on'
platform: state
condition:
condition: template
service: script.set_hue_scene
data_template:
group: "Dining table"
scene: '{{ states.input_select.dining_table_scenes.state }}'
script:
set_hue_scene:
sequence:
data_template:
group_name: '{{ group }}'
scene_name: '{{ scene }}'
The group name makes we doubt, what should i put in the set_hue_scene {{group}} , this is my Hue group:
do i call the friendly_name between " " , or the entity name light.dining_table, or just dining_table.
In the latter case, it might interfere with the group name ive created for displaying in HA frontend…
![46](https://community-assets.home-assistant.io/original/3X/2/a/2a7f97d8f2d2f47e427bf1ff2b7c01dabb2bc388.jpeg)
group:
dining_table_lights:
icon: mdi:silverware
entities: &dining_table_group_entities
- input_select.select_hue_scene_dining_table
- light.dining_table_lamp_1
- light.dining_table_lamp_2
- light.dining_table_lamp_3
this is the error i get on all groups, which is very odd, since i have only 1 entity per name:
run_scene: More than 1 group found by name light.dining_table
Cheers,
Marius
It’s the group name on your hue hub, which I would guess is “Dining table”.
correct. Go it working alright! Had to go into the Hub Api though to find out why some of the Hue scenes weren’t recognized. Some where in English and some in Dutch. Most of them both…
Created a translated setup and rebooting as we write.
Still figuring out if its best to use the group name if there;s only 1 lamp in it, and not use the lamp-name. Any thoughts on that?
Another code optimization i would strive for is an automatic group name template in the automations.
As it is now, i have both automations for all of my 6 groups, which seems a bit much.
I have a selector in each group, so in total i have 6 selectors, 12 automations, and 1 script…
I like the efficiency of the 1 script ![:wink: :wink:](https://community.home-assistant.io/images/emoji/twitter/wink.png?v=9)
Surely adding some sort of extra selector for the group, could render this to be more efficient?
Select group, then select scene, and run script.
Cheers,
Marius
Sure. I only have one group of lights that are coloured so that’s just what I ended up with.
If you wanted one card for all the groups and all the scenes the most efficient way would be to get rid of all the automations completely and have a card with 2 input_selects and the script on it,something like:
input_select:
hue_scenes:
options:
- Arctic aurora
- Bright
- Concentrate
- Dimmed
- Energize
- Nightlight
- Read
- Relax
- Savanna sunset
- Spring blossom
- Tropical twilight
icon: mdi:creation
hue_groups:
options:
- Dining table
- Bedroom
- Living room
- Kitchen
icon: mdi:home
script:
set_hue_scene:
sequence:
data_template:
group_name: '{{ states.input_select.hue_groups.state }}'
scene_name: '{{ states.input_select.hue_scenes.state }}'
group:
Light Control:
- input_select.hue_scenes
- input_select.hue_groups
- script.set_hue_scene
Then you just set the scene, set the room and hit activate.
well this turned out nicely.
Created the following small package, and all lights are behaving as they should.
Accordign to the Hue Api reporting, even the white ambiance lamps support the colored Scene, which is a bit surprising f course, but I havent bothered to create separate scripts or scenes for the colored and non colored lights because of that.
I would like to see if i can somehow manage to show a .png instead of an mdi:icon in the group, because i like that better…more obvious Hue also…
One other thing i’m looking for now is to have a sensor display the state of the currently activated scene on a group.
I can change scene on my iPhone, and would like to have that reflected in the HA frontend also.
![01](https://community-assets.home-assistant.io/original/3X/0/9/09eb6df1ffaa49f48a5a383f550fc7ae6774239c.jpeg)
Package:
![30](https://community-assets.home-assistant.io/original/3X/a/1/a1c51f50ec6f948b29b799060782c4e981240be7.jpeg)
# Small package for selecting and activating Hue scenes and groups
# 02102018
homeassistant:
customize:
script.set_hue_scene:
icon: mdi:power
script:
set_hue_scene:
alias: Set Hue scene
sequence:
data_template:
group:
hue_light_control:
name: Hue Light Control
icon: mdi:spotlight
entities:
input_select:
hue_scenes:
name: Select Hue Scenes
icon: mdi:creation #palette
options:
- Select
- Arctische dageraad
- Savanne zonsondergang
- Tropische schemering
- Lentebloesem
- Concentreren
- Gedimd
- Energie
- Helder
- Lezen
- Nachtlampje
- Ontspannen
- Relax
initial: Select
hue_groups:
name: Select Hue Group
icon: mdi:group
options:
- Buffet
- Dining table
- Terrace
- Auditorium
- Corridor
- Master bedroom
Cheers,
Marius
@anon43302295
hi, back for another question please:
next to the above i have a few scenes id like to trigger separately . They seem to reach the appropriate lights, but the colors aren’t set correctly .
The numbers are right, because taken from the reading the lights give me when i set them with the app.
What could be wrong do you think? do i need to enter it differently in the scenes? I’ve already commented out the rgb’s cause they conflict with the color_temp. Maybe put these back and take out color_temp? please have a look?
- name: Bedside naar bed
entities:
light.bedside_table:
state: on
transition: 4
brightness: 37
color_temp: 153
# rgb_color: [171,58,22]
- name: Kist opstaan
entities:
light.kist:
state: on
transition: 4
brightness: 199
color_temp: 153
# rgb_color: [255,93,42]
- name: Dining table selamat makan
entities:
light.dining_table_lamp_1:
state: on
transition: 4
brightness: 206
color_temp: 443
light.dining_table_lamp_2:
state: on
transition: 4
brightness: 206
color_temp: 443
light.dining_table_lamp_3:
state: on
transition: 4
brightness: 206
color_temp: 443
- name: Kantoor aan de slag
entities:
light.bureau:
state: on
transition: 4
brightness: 233
color_temp: 370
light.inside:
state: on
transition: 4
brightness: 127
color_temp: 370
# rgb_color: [218,176,100]
light.outside:
state: on
transition: 4
brightness: 127
color_temp: 397
# rgb_color: [222,174,91]
Off th top of my head I don’t think you can set color_temp and color at the same time. Just set the color and see if that works?
testing now indeed, but it was the combi of brightness and color_temp giving me the unwanted settings.
