I am trying to use my yeelight lamps with home assistant.
Unfortunately I am unable to locate them automatically and the documentation is not of great help
If I follow the manual road, then the lights appear in overview, but not on the “Entities” list.
And although from the web interface I can click them on and off, I can’t find out their entity_id and thus can’t use them in any automation.
I have the feeling that I am missing something crucial … can you help ?
In my system this was under “Developer Tools” -> “States”
Now I can properly see them.
It looks like the id is the same with their “name”, when changing spaces with underlines etc.
I can see that the entity is light.pc_light, while the name in the configuration is PC light.
Similarly the friendly_name is (obviously) PC light.
Btw is is possible the id name not to be created automatically by it’s name? Or, in other words, to have a “special” friendly_name (i.e. localized), while keeping the entity_id as ASCII (i.e. english) and more simple?
A lot of the entities use the “name” or “alias” to automatically generate entity_id’s but not all. there are a few domains (scripts, all of the “input_xx” domains, etc) you actually specify the entity_id in the config.
And then there are ways to modify the entity_id on some domains. Those are the ones in the entity registry.
As far as changing the friendly name you can do that ion a couple of ways depending on the domain. One is if it is included directly in the entity config. the other way to do it is to create the friendly_name in the “customize:” section of the config.
