Hi folks,
Apologize for having to ask, but after reading through the documentation and about 50 threads, I’m still stuck.
I recently used a YouTube video from “The Hookup” to migrate my Home Assistant instance from a pi3 to Virtualbox. All seems well except for figuring out which port to specify for the Conbee stick.
I’m using the Supervisor/Hassio deconz integration, and that’s running the latest version. When I got to Hardware, my available listed port choices are:
- serial:
- /dev/ttyS2
- /dev/ttyS3
- /dev/ttyS1
- /dev/ttyS0
…all of which lead to an endless loop of:
11:50:16:516 wait reconnect 9 seconds
etc, which the threads seem to say is showing I haven’t chosen the right port.
Likewise, in Phoscon itself if I look at the gateway the firmwear setting shows not connected, which verifies the above as not the correct port.
I found a reference in some of the Conbee docs to something about needing to give the user authorization to a permission group, but don’t know if that’s needed with the Hassio integration or if so honestly how to do it.
Any help gratefully appreciated!
