mattmole
(Matthew Holder)
July 27, 2017, 7:28pm
1
How would I create a template sensor that shows the maximum value from an MQTT sensor?
I’ve tried the following, but see an error relating to a python dict item not being available:
platform: mqtt
state_topic: “/house/nursery/temp”
unit_of_measurement: “C”
name: “Nursery temperature”
platform: template
sensors:
max_nursery_temperature:
friendly_name: “Maximum temperature”
value_template: {{ max(states.nursery_temperature) }}
keithh666
(Keith Hull)
July 27, 2017, 8:08pm
2
I use some sensor templates…
sensors:
greenmaxtemp:
friendly_name: 'greenhouse max temp'
value_template: >
{% set greencurrenttemp1 = (states.sensor.gh_sensor_temp.state | float) %}
{% set greencurrent_threshold_max = (states.input_slider.green_max_temp.state | float) %}
{% macro max(X, Y) -%} {{X|float if X|float > Y|float else Y|float }} {%- endmacro %}
{{ max(greencurrent_threshold_max, greencurrenttemp1) }}
sensors:
greenmintemp:
friendly_name: 'greenhouse min temp'
value_template: >
{% set greencurrenttemp2 = (states.sensor.gh_sensor_temp.state | float)%}
{% set greencurrent_threshold_min = (states.input_slider.green_min_temp.state | float) %}
{% macro min(X, Y) -%} {{X|float if X|float < Y|float else Y|float }} {%- endmacro %}
{{ min(greencurrent_threshold_min, greencurrenttemp2) }}
And some input sliders…
green_max_temp:
name: Greenhouse Max Temp
initial: -40
min: -40
max: 50
step: 0.01
green_min_temp:
name: Greenhouse Min Temp
initial: 50
min: -40
max: 50
step: 0.01
mattmole
(Matthew Holder)
July 27, 2017, 8:32pm
3
Thanks Keith,
Am I right in saying that yours compares two different values to find which is the highest and which of a pair is the smallest?
I’m trying to look through the history of all values from my nursery sensor and then display this.
Matt
keithh666
(Keith Hull)
July 27, 2017, 8:37pm
5
Mine stores the lowest and highest values in the input sliders and compares against the read ones from the sensors. I store the values to disc so that they permanent immediately after they have changed.
mattmole
(Matthew Holder)
July 27, 2017, 8:52pm
6
Thank you. I’ve tried the statistics sensor, but it doesn’t seem to read data from the history.
I’ll try the history statistics sensor to see how I get on with that. I’d then like to reference the maximum value only so that I can get this returned by an Alexa skill.
Matt
