Hi everyone,
I have 3 ct clamps connected to the mains and am wondering about accuracy.
For this experiment, I connected all 3 CT clamps to the very same circuit, where only the fridge is connected to. I also have an energy measuring plug for the fridge.
In the image you see the power consumption as calculated by the 3 CT clamps and the power as calculated by the plug. As you can see, I’m facing with 2 problems:
- I have a constant noice from the CT.
- the CT measurements don’t go to zero, they go to unavailable (same for the amperage)
Please note that the voltage measure I’m using for the power calculation is coming from the smart plug.
here is my ESPhome code:
- platform: ct_clamp
sensor: adc_sensor_i1
update_interval: 2s
sample_duration: 2s
filters:
- calibrate_linear:
# Measured value of 0 maps to 0A
- 0 -> 0
# 1 V --> 30 Amp from CT sensor
- 1.0 -> 15.0
sensor: adc_sensor_i2
update_interval: 2s
sample_duration: 2s
filters:
- calibrate_linear:
- 0 -> 0
- 1.0 -> 15.0
sensor: adc_sensor_i3
update_interval: 2s
sample_duration: 2s
filters:
- calibrate_linear:
- 0 -> 0
- 1.0 -> 15.0
- platform: adc
pin: GPIO32
# raw: true
attenuation: auto
# update_interval: 1s
- platform: adc
pin: GPIO33
# raw: true
attenuation: auto
- platform: adc
pin: GPIO34
# raw: true
attenuation: auto
- platform: wifi_signal
update_interval: 60s
these are the ct clamps I’m using (15A → 1V)
and this is the circuit I’m using for wiring them.
Any suggestions on how to solve the problems?
Thanks!
