FingerBot BLE device control
Hi. I have a couple of FingerBot BLE devices… What is the best way (or is there any way?) to integrate these with HA? I am using HAOS on a RPI 4.
Thank you!
Did you ever figure this out?
Unfortunately not… hopefully someone does one day…
Use the Smart Life app and then
https://www.home-assistant.io/integrations/tuya/
I think this gets us close - but I am not sure about python and HA?
https://www.reddit.com/r/homeassistant/comments/10ogtbt/tuyaadaprox_fingerbot_to_home_assistant/
I am sure someone could produce an integration from this info :slight_smile:
Should the python code run in appdaemon?
Thank you!
Yep, the Tuya BLE integration works, and no hub required :slight_smile:
