Finite State Machine Sensor
I really like FSMs, I find they make it much easier to reason about more complex automations. So I created a custom component that creates sensors backed by the transitions library.
Configuration
Currently configured using a JSON schema that is very close to Node Red’s
A special timeout trigger is supported for time-based automatic transitions.
Example Config
Tracks the state of a dryer starting up, running, and stopping. The automation sends above,
below, and middle triggers based on the dryer’s power consumption. Automatic transitions
happen from STARTING to RUNNING after 1 second, from STOPPING to DONE after 2 minutes, and
from DONE to IDLE after 15 seconds.
  "state": {
    "status": "IDLE"
  "transitions": {
    "IDLE": {
      "above": "STARTING"
    "STARTING": {
      "timeout": { "after": 1, "to": "RUNNING" },
      "below": "IDLE"
    "RUNNING": {
      "below": "STOPPING"
    "STOPPING": {
      "timeout": { "after": 120, "to": "DONE" },
      "above": "RUNNING",
      "middle": "RUNNING"
    "DONE": {
      "timeout": { "after": 15, "to": "IDLE" }
Example Automation
Uses the FSM above, configured as sensor.dryer_state. Triggers are a faux drier power meter
input_number.dryer_power and the FSM sensor when it transitions to the DONE state where
we want to take an action.
The automation uses the state_machine.trigger service to send triggers to the sensor.dryer_state
state machine entity based on the dryer’s current power.
When the state machine eventually cycles to DONE that trigger results in a notification being sent.
alias: Drier Notifier
description: ""
  - platform: state
    entity_id:
      - input_number.dryer_power
  - platform: state
    entity_id:
      - sensor.dryer_state
    to: DONE
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: notify.notify
              message: Drier Is Done
    default:
      - choose:
          - conditions:
              - condition: numeric_state
                entity_id: input_number.dryer_power
                above: 50
            sequence:
              - service: state_machine.trigger
                  trigger: above
                  entity_id: sensor.dryer_state
          - conditions:
                below: 15
            sequence:
                  trigger: below
        default:
              trigger: middle
mode: queued
max: 10
This is wonderful - Thanks to your hard work I can now easily recreate some of my previous node-red FSM flows directly in the HA.
That is my biggest use-case as well. I’ve been able to much more easily migrate my last few automations off Node Red.
Please let me know if you hit issues, have questions, etc. I’ll eventually get this installable via HACS.
I’m sure I’m missing something - where do I drop in my JSON config? Also - will this state machine survive a system restart?
It took my a bit of tinkering to figure this out too. When you go to create a new state machine in the helpers section, it will open a config menu with two options, a “name” and a “JSON schema” text field. The JSON schema field is where you put your state machine JSON. The whole JSON contents. It’s not a field for a file name, its literally the whole JSON string. Yes, this is very confusing.
Also, the state machine definition survives a system restart, but I dont think the active state will survive a restart. E.g. if you had a state machine that starts in “IDLE” and transitions to “RUNNING” if a system restart were to happen while in the state “RUNNING” I believe that state will be “IDLE” when the system comes back up.
This is just genius :heart:
