Fios G3100 Gigabit Router, Help!
Has anyone got DuckDNS running with a Fios G3100 Gigabit Router? I believe this is their newest router and for some reason, I can’t get the Port Forwarding to work. I set up it up just like the previous router forwarding 443 to the Hasio 443 but it still seems to get blocked. Any thoughts?
On my old router it’s working, but now I have new G3100 router. I did set port forwarding same way I did on old router. When connecting from local network using https://xxxxxxxxx.duckdns.org/ have error: Oops.
The site at https://xxxxxxxxx.duckdns.org/ has experienced a network protocol violation that cannot be repaired.
The page you are trying to view cannot be shown because an error in the data transmission was detected.
Please contact the website owners to inform them of this problem.
But if I disabled wifi on phone and connect to https://xxxxxxxxx.duckdns.org it’s works. no problems.
Update*****
After changing Advanced > System Settings > Primary HTTPS Management Port from 443 to different port, everything start working as it must.
