I’m looking to get a Fire HD 8 tablet to use as a home assistant wall mounted dashboard. Do I need to pay more and get the one “without special offers”?
The “special offers” are ads on the lockscreen, so that depends on if you can live with that
Would I even see them? I was imagining having the tablet screen only turn on when 1) I send some sort of command to it (ex. show camera stream, show alert - I don’t even know if this is possible) or 2) when someone touches the screen.
Bear in mind that the fire tablets use an old version of webview, which causes problems with some browsers (e.g. fully) and custom components. Also, you can’t disable the lockscreen.
I have just swapped my fire tablets out with Lenovo tab 4s for this reason.
Thanks. Are you able to do these things on the Lenovo:
You can search for the program “Amazon Fire Toolbox” to get rid of Amazon ads, get rid of everything Amazon and disable system updates. The program works on most HD8 and HD10 models, at least the recent ones released in 2016-2018. That program is most useful if you want to convert your Fire tablet to an Android-like tablet. The new version also installs Google Assistant, but I don’t know if it is always-on. I would rather rely on a Google Home or a speaker that has better microphones for voiec commands.
What srk23 said, there’s no getting around the old version of Webview (new version is necessary for custom Lovelace cards), except using Google Chrome as the browser for Home Assistant. I also haven’t been able to disable the lockscreen. There aren’t any ads on the lockscreen anymore, but I can’t just press the power button and have it load Home Assistant yet. It stays on the lockscreen until someone swipes up to unlock.
If you configure Firebase Cloud Messaging (FCM) with Home Assistant, you can send notifications to the tablet like any app would do. Or you can create persistent notifications in Home Assistant, so the notification shows up in the HA notifications tab.
I haven’t tried most of these. But the Lenovo is a standard android tablet running a recent android version, and can easily be rooted if required. So if you can’t do it on the Lenovo, you probably can’t do it on any android tablet.
I have mine mounted to the wall with 3m velcro and powered using a cannibalised qi charging pad with a flat connector. Looks neat, and using the fully browser works very well.
Thanks for the quick response. Can you post the product links for the pad and connector?
I also see there is a “Lenovo Tab 4 10” and a “Lenovo Tab 10”. Any recommendations and key differences?
I am using the Lenovo pad 4 8. The pad 4 10 is the larger version. Returned versions can be had pretty cheap on eBay.
The connector is a micro usb qi receiver. I removed the connector from the pad and soldered wires to a 5v supply (stepped down from old 12v alarm keypad wiring).
I got mine from banggood, but similar to:
So I just ordered a Lenovo pad 4 8 - thank you. Any walkthrough on how to set it up as a home assistant dashboard would be appreciated.
Install fully kiosk browser, point it to your Lovelace URL, done!
There are settings to start on boot etc. You can also enable motion detection to allow the screen to turn on when the front camera detects motion.
Nice - arrives Thursday! I plan to start by putting it on the wall in the master bedroom and to have it just be informational (i.e. display driveway camera if motion detected, show message when garage opens). I don’t intend to touch it. Hopefully that works.
I second @srk23’s suggestion. I’ve done exactly that to use my fire 7 as an alarm keypad that dynamically displays when one of the doors or windows is left open so I don’t try and arm the alarm if anything was left open.
This is a pic I took before hiding the power cable in the wall:
Source: Me, had the same doubt, bought it anyway and send them a email on someone’s advice. They replied within 24 hours.
can you share your config on how you access the camera of the kindle fire?
here:
To access the camera you’ll need to install Fully Kiosk and @thomasloven’s fully kiosk module
Lovelace-fullykiosk is not required for the camera feed. But there’s a description in the readme on how to do it.
Or… Root and load LineageOS
Can you point me in the right direction? Tried rooting, but mine wasn’t rootable.
I have the Kindle Fire 7 and it’s running 5.6.4.0. I’ve looked all over the internet, but couldn’t find a tutorial that worked on mine.
