for development of automations and error debugging, it would be very helpful if you can add a button to the trigger context menu that will fire the trigger that you selected.
After that you could check the traces if everything went fine.
This would help that you don’t need a device to test (you can develop from remote also) and sometimes you can’t test it easy (f.e. weather changes):
