i have a temperature/humidity sensor ts0201, im trying to create a automation to fire notification on my lg webos tv every time the temperature changes(up or down, any value), everything is working fine except the trigger… im a beginner on home assistant and maybe the solution is obvious but need some help… thank you
Hi there. In this particular case instead of using a device type trigger, you can use a numeric state type of trigger. It should work fine for you. Please try this.
