I have an Amazon Fire TV which I have been using for a while and has started having connection issues. It was originally using the AndroidTV integration, but since it was having errors that wouldn’t resolve, I deleted the integration to set it up using the FireTV integration.
It no longer will connect, it keeps failing under both the FireTV and AndroidTV integrations. So I tried to restore a backup from a few days ago thinking that would restore the integration, but it isn’t there anymore.
I have checked and ADB is turned on and verified the IP address was correct in the TV settings.
I have tried both integrations using the default settings, tried all 3 options for both (auto, androidtv, firetv) and every time I get the error “failed to connect”.
Any suggestions how to fix this? I use this for several automations.
