Weird problem after upgrade on firefox. my entity card is displaying in one column in stead of two. In other words my switch name was on the left and switch under that instead of aligned with the right side of the card. I downgraded to 2021.5.x and it went back to normal.
Running HomeAssistant /Home-Assistant in docker on unraid
Odd indeed. I tried clearing the cache for the relevant site multiple times. No change. To be certain I now tried to clear all cached data and now it is back to normal.
Seems it was not enough to clear cached data for the specific site, but needed to clear cache for some other sources too. Home Assistant pulling data for the UI from other source than the Home Assistant device? For next time, is there any advise on which sitesâ cached data would be good to clear?
Same problem here for me. I tried clearing the cache and cookies on Firefox and it did sort of fix it for a couple of rows but as soon as I refreshed again it was all messed up. You can see the difference pretty clearly in these two screenshots.
With Firefox browser open, press Shift+F2 to open the Developer Toolbar. This usually appears at the bottom of the browser window. Type âappcache clearâ, then Enter, to clear the cache.
Thanks for replying⌠Unfortunately Shift-F2 no longer opens the developer toolbar and the GCLI is no longer present in Firefox. There is a web developer toolbar that has a console screen where you can enter commands but the âappcache clearâ command is not recognized.
Wish I could make this work on Firefox. I can load that file but refreshing it/hard refreshing it doesnât change anything. Would love to find a workaround because it makes my HA dashboard look ridiculous on Firefox.
