Hello, I cannot open most pages… when i try iframe … is there a solution ?
Did I make something wrong ?
https://www.home-assistant.io/integrations/panel_iframe/
This is a limitation of all web browsers (for security) not Home Assistant.
Your only option is to ensure home assistant and the web pages you are viewing both either use HTTP or both use HTTPS.
Thanks for this, but I can open both pages ( HA also and Solar Assistant ) without “S”
Both are with http:// IP …
So I think this is not the problem ?
So I just translated your error (it helps if you post this in English) and it says that it is the site 192.168.1.78 itself that does not allow embedding. Nothing to do with Home Assistant.
What is this webpage?
Thanks to you …
Both pages are running local ( Homeassistant and also Solar-Assistant ) both on 2 different Raspberry `s ).
So It would be nice( and with very little risks ( I think ) when i can say to Homeassistant and also to Solar-Assistant, that they can trust eachother and embed one in the other
But how ?
That is solar assistant configuration option - if it has it. Not home assistant.
It has none …
so it seems there is no way for this ?!
Correct. If the source does not allow embedding there’s nothing HA can do.
