Firepace control with ESP
Hi!
I have a fireplace and I installed a thermocouple max6675 (inside) with an ESP32.
This thermocouple gives me the fireplace internal temperature and I would like to create a template that shows me this in a entity card:
Temp between 0° to 50° --> Fireplace OFF
Temp between 50° to 150° --> LOW TEMP, CECK THE FLAME
Temp between 150° to 300° --> Fireplace is OK
How can i get this?
Many thanks in advance
Do you want to template this in esphome, or home assistant?
If home assistant, what is the entity id of the temperature sensor?
If esphome, show your config.
I prefer in ESPHome…this is my config:
esphome:
  platform: ESP32
  board: esp-wrover-kit
  on_loop:
    then:
      - lambda: delay(5);
wifi:
  ssid: "name"
  password: "pass"
  power_save_mode: none
  fast_connect: true
  manual_ip:
    static_ip: 192.168.1.30
    gateway: 192.168.1.1
    subnet: 255.255.255.0
logger:
api:
ota:
spi:
  miso_pin: GPIO12
  clk_pin: GPIO14
  - platform: max6675
    cs_pin: GPIO15
    update_interval: 10s
  - platform: wifi_signal
    update_interval: 60s
  - platform: uptime
    internal: true
Probably some template sensor in esphome. I’m not up on lambda notation so I’m at a loss on the code.
text_sensor:
    lambda: |-
#some if/then code
      return {"Off"};
# else if temp is over 50
      return {"Unknown - Check the flame"}
# else
      return {"OK"}
    update_interval: 15s
I don’t think I understand how to do it :sweat_smile:
  - platform: max6675
    cs_pin: GPIO15
text_sensor:
    lambda: |-
if (id(fire_temp).state == under 50)
      return {"Off"};
# else
      return {"OK"}
    update_interval:
< 50
not under 50
Many thanks!
This is the final configuration (tonight I’ll try if it works well)
text_sensor:
#STATO FUOCO STUFA
    lambda: |-
     if (id(fire_temp).state  < 50)
      return {"SPENTO"}
     ;else if (id(fire_temp).state  > 50)
      return {"BASSO - controllare!"}
     ;else (id(fire_temp).state  > 140)
      ;return {"NORMALE"};
That’s never going to have the state " Normal". As the > 50 test will always be true before it gets to > 140. Try this
    lambda: |-
      if (id(fire_temp).state  > 140);
        return {"NORMALE"};
      else if (id(fire_temp).state > 50);
        return {"BASSO - controllare!"};
      else;
        return {"SPENTO"};
Also rather than polling the sensor every 15 seconds, update it when the temperature changes:
  - platform: max6675
    cs_pin: GPIO15
    on_value:
      then:
        - component.update: fire_state
Ok thanks tom, I will try this.
Can I set the different icon color for the 3 states?
For eample: red icon for state NORMALE, black icon for state SPENTO
Immagine11
No, I don’t think you can do that. You’d have to use card mod in home assistant.
Ok!
Last question, with this sensor, can I display degrees without decimals?
I would like to see 1 degree steps without decimals (now is 29.5 etc)
  - platform: max6675
    cs_pin: GPIO15
accuracy_decimals
Hi!
In ESPHome I created this template, which it tells me if the fire is ON (“ACCESA”) or OFF (“SPENTA”).
    icon: "mdi:fire"
    lambda: |-
      return {"ACCESA"}
     ;else
      return {"SPENTA"};
Is it possible to display a time as an output value?
For example:
return {"ACCESA alle 18:00"}
return {"SPENTA alle 23:00"}
