I wanted to open some discussion on potential changes to support Gas/Electric fireplaces in Home Assistant. And if we come to a consensus I’m happy to write the code myself.
I’ve been working on building out an integration for my Intellifire WifiModule fireplace.
The fireplaces have the following features:
- Light (
light.py
) - Fan (
fan.py
) - Thermostatic on/off control (
climate.py
) - Sleep Timer (not yet implemented)
- Flame Height (???)
Gas Fireplaces can be used as a primary heating source and if the thermostatic mode is engaged they function juts like a normal furnace. If its too cold the flame comes on - if its too hot it goes off.
What I’m struggling with is the best way to implement the flame height separately without making it too tacky.
I’m considering using a fan
entity as the flame height pretty much maps to a fan well. If I wanted to use the climate
entity - I was thinking I could tie into AUX_HEAT
if there was an optional field to set AUX_HEAT_LEVEL
This may not be a valid mapping, however, because most furnaces are only 2 stages and aux_heat
really is meant to represent stage 2 heating.
So this is more of a question for the community → do you see value in having:
- A separate
fireplace
entity - Modifying the climate entity so that it could support a gas fireplace.
Writing the code isn’t the holdup here - its a discussion on what would actually be useful and or make sense for HA.
