I tried to setup the new FireTV component, but failed.
I created an adb key from my windows
On my Fire TV Stick I confirmed, that the key has always access to the stick
I copied the keys (both) to my config
The key has permission 644
I’m not connected with my computer to the stick anymore
Here is my log:
2018-12-05 22:22:50 WARNING (SyncWorker_19) [root] Couldn't connect to host: 192.168.xxx.xx:5555, error: Connection reset by peer
2018-12-05 22:22:50 ERROR (SyncWorker_19) [homeassistant.components.media_player.firetv] Failed to execute an ADB command; will attempt to re-establish the ADB connection in the next update
2018-12-05 22:23:01 ERROR (SyncWorker_8) [homeassistant.components.media_player.firetv] Failed to execute an ADB command; will attempt to re-establish the ADB connection in the next update
2018-12-05 22:23:12 ERROR (SyncWorker_11) [homeassistant.components.media_player.firetv] Failed to execute an ADB command; will attempt to re-establish the ADB connection in the next update
2018-12-05 22:23:24 ERROR (SyncWorker_11) [homeassistant.components.media_player.firetv] Failed to execute an ADB command; will attempt to re-establish the ADB connection in the next update
2018-12-05 22:23:34 ERROR (SyncWorker_9) [homeassistant.components.media_player.firetv] Failed to execute an ADB command; will attempt to re-establish the ADB connection in the next update
Here is my config:
media_player:
- platform: firetv
name: Fire TV Stick 4K WG
adbkey: "/config/android/adbkey"
I restarted my home assistant, but still the same issue. I also created a new key pair, but still the same issue.
I have the new 4K Fire TV stick.
Are you sure you can ping your FireTV ? I mean that everything is connected to your wifi ?
Here are some other discussions, you are not alone having errors, and the problem seems quite complex. Hope this helps, good luck!
Ah, cool. Someone in the same boat! I’ve got the same problem and I hardly doubt that it’s a network problem. Any of my other devices work perfectly on the network. I noticed that it seems to sort of work if I start Home Assistant and do nothing with the component. Then it (sometimes) shows the state of the Fire TV. But as soon as I perform an action, say, turning it on, it will break. So I guess it’s a bug with the component or - as suggested by a1ex4 - with the python-adb library: https://github.com/google/python-adb/issues/136
There have been times that, especially after a power cycle, I have had to visit each firestick and do a restart on the device before HA would play nice with it again.
