edit: I figured the issue out. When using the docker I linked below, you have to name the device with the same name in your HASS config.yaml file that is in docker house.yaml file.
Hope this helps someone else.
I’m looking to incorporte my 3 fire sticks into HASS. I am using the docker image: https://hub.docker.com/r/sytone/python-firetv/. When I look at the docker log it shows the below message and it looks like the image sees at least one of my firesticks.
.When I add to HASS it get:
Has anyone seen this error message before?
