Firewall and Google Home Assistant
I just got a Google Home Mini which i would like to integrate to HASS and i can see that it requires that i open up my HASS to the public which i am not big fan off unless i can set up rules in my firewall to allow access only from google servers. Anyone done that ?
Is Amazon Echo any different in this regard i mean having to open up HASS to external access ?
/donnib
The problem is, Google have many IP ranges it’s not as simple as that. You could watch your logs and see what ranges they’re using for you.
I use NGINX, which gives me the ability to only allow POST requests with the user agent including Google-Cloud-Functions, which all the legitimate requests will have. I’ve not bothered though - I run Home Assistant on a random port, and in the last year I’ve seen a grand total of zero probes (never mind attempts) in my logs.
Alternatively, wait for the cloud: component to deliver Google Home integration. That should hopefully turn up over the next few months.
As for the Echo, if you use alexa: you also need to open up access. Only emulated_hue: doesn’t require you to open ports.
Cool thanks for the reply, yes i was kind of expecting that but i was thinking maybe i could use a wildcard and use hostnames in the firewall. I could go ahead and do it then monitor how the server get’s contacted to see if there are anyway i could allow only from Google.
Don’t ever use reverse DNS for filtering. Anybody could set up a reverse DNS to claim to be Google.
Two years later already, but I was having the same question. I did find a solution and I post it so maybe others can use this information.
I tested for some weeks which IP addresses accessed my HA. This resulted in the following 3 ranges for Google Assistant:
66.249.93.0/24
66.102.9.0/24
108.177.64.149
I set up my firewall for these and GA is working perfectly for many weeks already.
@Hs82H Thank you very much. It works really well. But I saw a request on my firewall from the address 108.177.64.49. For this reason, I have had to expand the area. My current config is the following:
66.249.93.0/24
66.102.9.0/24
108.177.64.0/24
Thanks Philipp! I noticed it was working 99% of the times and I could figure out why it didn’t for the last 1%. This solves the issue!
Almost 2 years later again. I want to set up Google Home manually, so do these 3 ranges still work?
Another 2 years later and apparently the ranges are not working anymore, at least not for me :frowning:
Does anybody know the new ones or is it still working for somebody else?
