Hi there. When I upload StandardFirmata.ino to my Arduino board, it all works ok
But, I have some custom code, from that code I would like to pass a value to HASS via: Firmata.sendAnalog(analogPin, MyOwnValue);
I get stuck very fast, taking again StandardFirmata, then only add/modify this part in the main loop:
void loop()
byte pin, analogPin;
/* DIGITALREAD - as fast as possible, check for changes and output them to the
* FTDI buffer using Serial.print() */
checkDigitalInputs();
/* STREAMREAD - processing incoming messagse as soon as possible, while still
* checking digital inputs. */
while (Firmata.available())
Firmata.processInput();
// TODO - ensure that Stream buffer doesn't go over 60 bytes
currentMillis = millis();
if(currentMillis - prev_cntr_millis > 1000)
prev_cntr_millis += 1000;
if(test_cntr < 255)
test_cntr++;
else
test_cntr = 0;
if (currentMillis - previousMillis > samplingInterval)
previousMillis += samplingInterval;
/* ANALOGREAD - do all analogReads() at the configured sampling interval */
for (pin = 0; pin < TOTAL_PINS; pin++)
if (IS_PIN_ANALOG(pin) && Firmata.getPinMode(pin) == PIN_MODE_ANALOG) {
analogPin = PIN_TO_ANALOG(pin);
if (analogInputsToReport & (1 << analogPin))
//Firmata.sendAnalog(analogPin, analogRead(analogPin));
Firmata.sendAnalog(analogPin, test_cntr);
// report i2c data for all device with read continuous mode enabled
if (queryIndex > -1) {
for (byte i = 0; i < queryIndex + 1; i++) {
readAndReportData(query[i].addr, query[i].reg, query[i].bytes, query[i].stopTX);
#ifdef FIRMATA_SERIAL_FEATURE
serialFeature.update();
#endif
Idea is that the variable test_cntr should be send when reading a certain Analog input, for some reason, in HASS, I see this input changing about eacht 30sec, from 0-40-80-120-160-200-0
Strange thing is, that in the “Windows Remote Arduino Experience” App, it simply works! What can be wrong, something with timing?
Controlling a digital pin via HASS does work responsive fast. The issue seems to be analog input related.
