AshDeva
(Ashokkumar)
August 2, 2019, 5:14am
1
I am using raspberry pi 3 B+ and raspbee premium. I have flashed HassOS and made changes in the config file as following
enable_uart=1
dtoverlay=pi3-miniuart-bt
dtoverlay=uart0-full
core_freq=250
(left blank line)
Installed deconz addon, changed the device in deconz configuration as /dev/ttyS0 and also tried with /dev/ttyAMA0 , but none of this helped
I tried all possible combinations, but still it shows firmware not connected. I have also tried other way by flashing raspbian and directly installing deconz but i face the same problem over there.
opened 04:35PM - 31 Jul 19 UTC
closed 12:25PM - 19 Dec 19 UTC
I am using raspberry pi 3 B+ and raspbee premium. I have flashed Raspbian Stretch Desktop(2.05.63) SD card image and tried...
I am banging my head for past one week. Some help on this will be great
AshDeva
(Ashokkumar)
August 2, 2019, 5:27am
2
logs from deconz
[05:24:05] INFO: Starting the deCONZ gateway…
[05:24:05] INFO: Running the deCONZ OTA updater…
[05:24:05] INFO: Running the IKEA OTA updater…
[05:24:05] INFO: Running Hass.io discovery task…
{“uuid”:“f165b15c8c9f42afbc73a199a41aa3bb”}
[05:24:06] INFO: Success send discovery information to Home Assistant
[05:24:06] INFO: deCONZ is set up and running!
libpng warning: iCCP: known incorrect sRGB profile
This plugin does not support propagateSizeHints()
05:24:06:416 HTTP Server listen on address 0.0.0.0, port: 40850, root: /usr/share/deCONZ/webapp/
05:24:06:449 CTRL. 3.16.205:24:06:534 dev /dev/ttyAMA0
05:24:06:535 COM: /dev/ttyAMA0 / serialno:
05:24:06:535 COM: --dev: /dev/ttyAMA0 (RaspBee)
05:24:06:535 ZCLDB init file /data/.local/share/dresden-elektronik/deCONZ/zcldb.txt
05:24:06:712 parent process bash
05:24:06:712 gw run mode: docker/hassio
05:24:06:712 GW sd-card image version file does not exist: /data/.local/share/dresden-elektronik/deCONZ/gw-version
05:24:06:712 sd-card cid: 035344534333324780ffffffff01375f
05:24:06:714 DB sqlite version 3.16.2
05:24:06:716 DB PRAGMA page_count: 30
05:24:06:716 DB PRAGMA page_size: 4096
05:24:06:716 DB PRAGMA freelist_count: 0
05:24:06:716 DB file size 122880 bytes, free pages 0
05:24:06:716 DB PRAGMA user_version: 6
05:24:06:716 DB cleanup
05:24:06:717 DB create temporary views
05:24:06:723 don’t close database yet, keep open for 900 seconds
05:24:06:724 started websocket server at port 40860
05:24:06:728 discovery updated announce interval to 10 minutes
05:24:06:732 found node plugin: libde_rest_plugin.so - REST API Plugin
05:24:06:735 found node plugin: libde_signal_plugin.so - Signal Monitor Plugin
05:24:08:992 found node plugin: libstd_otau_plugin.so - STD OTAU Plugin
05:24:09:022 dev /dev/ttyAMA0
05:24:09:022 COM: /dev/ttyAMA0 / serialno:
05:24:09:022 COM: --dev: /dev/ttyAMA0 (RaspBee)
05:24:09:542 device state timeout ignored in state 2
05:24:10:493 device state timeout ignored in state 2
05:24:11:491 device state timeout ignored in state 2
05:24:12:025 dev /dev/ttyAMA0
05:24:12:440 discovery network reply error: Error transferring http://dresden-light.appspot.com/discover - server replied: Service Unavailable
05:24:12:500 device state timeout ignored in state 2
05:24:13:490 device state timeout ignored in state 2
05:24:14:491 device state timeout (handled)
05:24:14:991 wait reconnect 15 seconds
05:24:14:991 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
05:24:14:991 device state timeout ignored in state 1
05:24:15:990 wait reconnect 14 seconds
05:24:16:991 wait reconnect 13 seconds
05:24:17:594 Invalid admin password hash: $1$8282jdkm$w.o6XjJEGLzAYkVqLPAYx1
05:24:17:990 wait reconnect 12 seconds
05:24:18:991 wait reconnect 11 seconds
05:24:19:991 wait reconnect 10 seconds
05:24:20:990 wait reconnect 9 seconds
05:24:21:991 wait reconnect 8 seconds
05:24:22:033 dev /dev/ttyAMA0
05:24:22:267 created username: 8788EA7BA1, devicetype: Phoscon#B1440x713
05:24:22:991 wait reconnect 7 seconds
05:24:23:660 New websocket 192.168.0.102:57384 (state: 3)
05:24:23:991 wait reconnect 6 seconds
05:24:24:175 Websocket disconnected 192.168.0.102:57384 (state: 0)
05:24:24:991 wait reconnect 5 seconds
05:24:25:337 New websocket 192.168.0.102:57388 (state: 3)
05:24:25:990 wait reconnect 4 seconds
05:24:26:990 wait reconnect 3 seconds
05:24:27:043 don’t close database yet, keep open for 900 seconds
05:24:27:990 wait reconnect 2 seconds
05:24:28:381 Websocket disconnected 192.168.0.102:57388 (state: 0)
05:24:28:991 wait reconnect 1 seconds
05:24:29:026 dev /dev/ttyAMA0
05:24:29:026 COM: /dev/ttyAMA0 / serialno:
05:24:29:026 COM: --dev: /dev/ttyAMA0 (RaspBee)
05:24:29:519 device state timeout ignored in state 2
05:24:29:552 New websocket 192.168.0.102:57390 (state: 3)
05:24:30:490 device state timeout ignored in state 2
05:24:31:490 device state timeout ignored in state 2
05:24:32:028 dev /dev/ttyAMA0
05:24:32:491 device state timeout ignored in state 2
05:24:33:490 device state timeout ignored in state 2
05:24:34:491 device state timeout (handled)
05:24:34:990 wait reconnect 15 seconds
05:24:34:991 void zmMaster::handleStateIdle(zmMaster::MasterEvent) not connected goto OFF state
05:24:34:991 device state timeout ignored in state 1
05:24:35:991 wait reconnect 14 seconds
05:24:36:990 wait reconnect 13 seconds
05:24:37:991 wait reconnect 12 seconds
05:24:38:990 wait reconnect 11 seconds
05:24:39:991 wait reconnect 10 seconds
05:24:40:990 wait reconnect 9 seconds
05:24:41:990 wait reconnect 8 seconds
hi did you ever resolve this issue?
AshDeva
(Ashokkumar)
September 19, 2019, 4:44pm
4
No luck. I have tried everything and concluded that the problem is with the raspbee premium. I am going to try with a new raspbee premium and will update you on the same
simonq5
(Simon)
February 21, 2021, 8:08pm
5
Did you ever sort this issue?
I bought two of this rasbee shields / rasbpee premium (whatever you want to call them) the version 1 not the new version 2.
I was able to get one of them working in a rasberry pi with diyHUE installed
The second I cannot get installed in HomeAssistant no matter what I try with editing the config.txt and everything else.
I noticed a difference on the LED lights on the two raspbees.
The one that works in the diyHUE has a red left led light and when I got it working the right led flashes green. The red led is larger and brighter and stays on solid and the right green led is flashing and is smaller
The one that doesn’t work (in the HomeAssistant) has no led on the left and the right led is constantly green and bright. Even without an SD card in the pi or with an SD card in the pi, it doesn’t change.
I’m assuming the board is faulty…
Would love to hear what you found out man!
